Question about Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
Why wont my Nikon af nikkor 70-300mm G lens autofocus its self with my D5000 camera
It won't auto focus its self. I can focus it by myself but it wont point and shoot without me having to manually focus it. I'm wondering if it is compatible with my camera which is a Nikon D5000
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
The D5000 does not have a focus motor in the body, relying on the lens to have one. The old 70-300mm G lens does not have a focus motor, relying on the camera to have one. Thus, this combination will not autofocus.
The newer 70-300mm AF-S G lens, as well as the even newer 70-300mm VR AF-S lens, do have the autofocus motor and thus will autofocus on the D5000.
Posted on Jan 23, 2012
4 Suggested Answers
6ya staff
SOURCE:
poolseman
zdenek vajdak
  • 206 Answers
SOURCE: Nikon AF-s VR zoom-Nikkor 70-300mm
First the auto focus motor is in the body and not the lens so that will not be the problem. Unless you dropped the lens the problem is probably in the focus gear interface inside the lens ( it is stuck in the manual drive --that is why no autofocus-- and there is something preventing normal gear operation). Seems like a small problem but will require a look at the rear of the lens where the gear box is situated.
Posted on Sep 07, 2007
Anonymous
  • 667 Answers
SOURCE: Compabilty Nikon 70-300mm/f1:4-5.6G with KENKO 2 X TELECONVERTER MC4DG
Having a 'DG' in the name of the converter tells me, Yes...
Posted on Mar 27, 2008
ftw1952
frank thomas wilson
  • 10319 Answers
SOURCE: My Nikkor AF-S DX VR 18-200 stopped focusing
the lens internally has a electrical circuit ribbon that contracts when you adjust the lens everytime. They are prone to get crease causing a short in the auto mode.b It can be checked and replaced bt most camera technicians
Posted on Nov 06, 2010
Autofocus on Nikkor 18-55mm lens doesn't work
probably you have problem with the focus motor, i ever have same problem and need to replaced the focus motor.
Jun 08, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus. AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Dec 19, 2012 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
The auto focus does not work properly with this lens on either my Nikon D5000 or D7000. I have tried all possible combinations of AF settings. Typicaly, when I use single point to focus, the subject I...
Hi, It wouldn't autofocus on the D5000 as the body doesn't have an auto focus motor in the body and since that lens is AF, not AF-S, it won't autofocus. It should autofocus on the D7000 though, how far away are you from the object you're trying to photograph?
Aug 28, 2011 | Tamron SP AF 17-50mm f/2.8 XR Di II LD...
I have a Nikon D80 with AFS nikkor 18-135 lens, the problem is the camera doesn't make auto focus.
set the autofocus swith in the camera beside the lens to AF, and in the lens switch to AF
Jan 11, 2011 | Nikon D80 Digital Camera with 18-135mm...
Will the Quanta 28-200 for the Nikon n75 work on the Nikon D5000?
Yes and no. I assume the lens is of more or less the same vintage as the N75? If so, the lens will fit onto the D5000. All of the camera's exposure and metering modes will work properly. However the lens lacks an interal focus motor and thus will not autofocus on the D5000. You can focus manually, and the green focus indicator in the viewfinder will continue to work.
Apr 22, 2010 | Quantaray 28-200mm f/3.8-5.6 for Canon AF
Nikon auto focus lens not working, only in manual
What camera body? This lens doesn't have an internal focusing motor and thus will not autofocus on the D40/D40x/D60/D5000/D3000.
Sep 10, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
My Nikon D60 wont auto focus on any of my lenses. Could it be a problem with the body?
The d60 needs Auto focus lenses(Ones with motors inside the lense) it doesn`t autofocus on other lenses. this was done to reduce the price of the camera body
Hope this helps
Aug 04, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Lens works fine in manual focus on Nikon D5000 but won't autofocus.
The D5000 needs an AF-S lens to autofocus.
Nikon have not fitted the mechanical focus drive to the D5000.
Jun 22, 2009 | Nikon 10.5mm f/2.8G ED-IF AF DX Lens
Can't autofocus Nikon 50mm f1.8 lens
The lens has an autofocus motor, but because it is an older model, it will not autofocus for the D40(x), D60, or D5000, which have more stripped down components. I advise you exchange the lens for the newer model, or return the D5000 and get the D90 for just a bit more.
Jun 11, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon DX AF- S Nikkor 18-55 mm lens won't Auto focus
Is the switch on the side of the lens set to manual or auto? Sometimes it's the little things like this that we don't notice.
Apr 16, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon AF 70-300mm f/4-5.6 G Nikkor Lens Logo
411 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
