Tunturi T80 Programmable Treadmill Logo
Anonymous Posted on Dec 26, 2011
System check failed - Tunturi T80 Programmable Treadmill
tinagoldy
Level 1:
  • Contributor 4 Answers
  • Posted on Oct 18, 2013
tinagoldy
Contributor
Level 1:
Answers
Questions
0
Helped
2041
Points
5
Hi You need a new power board I got brand new power board for tunturi t80/t85 call +447943858686
  • 2 more comments
  • Costas Dalucas
    Costas Dalucas Dec 11, 2013
    Please do you still have a controller for T85? If so how much do I have to pay?
  • tinagoldy Dec 11, 2013
    Sorry sold
    You need a lower power board & if you are interested I can find out the price for you
    If anyone need tunturi t80/t85 power board contact uk benchmark fitness
ernesto cuadra
Level 3:
Top Expert:
  • Tunturi Master 12,223 Answers
  • Posted on Dec 26, 2011
ernesto cuadra
Tunturi Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4076355
Points
34431
  • Press the "On/Off" switch to turn the treadmill off.
  • 2Unplug the power cable at the bottom, base of the treadmill.
  • 3Push the safety switch in.
  • 4Plug the cable back into the treadmill and set the "On/Off" switch to "On."
  • ssincerely. Merry Christmas.
    ERNESTO CUADRAmanagua, nicaragua
    • salman karimi
      salman karimi Oct 13, 2013
      hi ernesto,i followed your instructions but my t80f treadmill still shows the ''sysytem check failed'' message! what should i do? thanks
      You need a new lower power board & you can only get it in uk
    My 2010 journey is over heating what can I do to stop it
    Figure out why and correct this issue. There are numerous things that can cause overheating and many are beyond the average do it yourself repair. Some possible causes are: failed thermostat, failed water pump, broken water pump belt, low coolant level, failed cooling fan, failed electrical cooling system, failed heater core, leaking hose, air pocket in cooling system, failed radiator cap, failed radiator, cracked head, cracked block, failed headgasket etc. Beware it only takes one time overheating to damage the cylinder head or headgasket. Get that checked.
    I have an older sno way 24D and when I lift the blade it looses preasure and falls. No fluid is leaking anywhere on ground. Is this the preasure switch? Oh yeah I started having this problem last year and...
    improper fluid or level ---valve fail--seal fail--pump fail --check valve fail --need to check ,test and inspect the system cleaning can help if debris caused a blockage but just cleaning doesnt fix problems when something fails
    1helpful
    My 1995 toyota tercel failed its smog check due to the OBD system check-fail
    Have the fault codes read and that will point to the faults that caused the problem
    1990 Cadillac biaritz engine check light on>>code E049 represents what?
    E049 - Air system faultECM failed to detect an increase of 15 or more integrator counts when air is diverted to exhaust manifold and system has failed 4 times.Check operation of air injection system, verify oxygen sensor operation,Check all hoses, pipes & wiring for damage.
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mike_a0891ab86974ea74
    3helpful
    How do i fix p1130 AND P 1440 code on my 2000 Nissan maxima? It takes about 5-6 minutes to crank up.
    P1130 Swirl Control Valve Circuit Malfunction - With Automatic Transmission Possible Causes
    • Check for air leaks in the Air Induction system (e.g., in the intake manifold)
    • Check for leaks or looseness in hoses and tubes between the intake manifold, vacuum tank and swirl control valve actuator
    • Check for leaks or looseness in the hoses between the air cleaner assembly and the swirl control valve vacuum check valve
    • Crankshaft position sensor (REF) signal problem
    • MAF sensor has failed (it may be dirty or contaminated)
    • One-way check valve has failed
    • Swirl control valve actuator has failed (it may be damaged or sticking)
    • Swirl control valve control connector is damaged (check pins for damage)
    • Swirl control valve circuit is open, shorted to ground or shorted to voltage
    • Swirl control valve has failed
    • PCM has failed
    • Throttle position sensor has failed
    • Vacuum tank has failed
    P1440...EVAP Control System (Small Leak)
    Check your fuel cap & reset code,
    Good luck, hope this helps,,,
    It started with 'Delayed Write Failed'. System not booting.
    You did not mentioned the model number of your hard disk and system. Any way try visiting the manufecturer's website and download the driver from suport or download section. ([email protected])
    Emission test failed code86
    check your exhaust valv and as for not being able to connect to OBD system, check all of your fuses.
    1helpful
    4answers
    Power edge 2600 sever shows problem
    i replaced one of the hard drives in my poweredge. how do i get it to copy from the good hard drive?
    Top Tunturi Exercise & Fitness Experts
    ZJ Limited
    ZJ Limited
    john h
    ADMIN Andrew
    ADMIN Andrew
    Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
