Here is the manual that matches your model scale: http://personalcare.manualsonline.com/manuals/mfg/conair/ww39.html?p=2
Best wishes,
Joe
I’m happy to help further over the phone at https://www.6ya.com/expert/mark_7bbaa7a1174e0903
SOURCE: Looking for Conair/Weight Watchers WW83 instruction Manual
http://www.conaircanada.ca/en/pdf/ibs/en_WW83C.pdf this is a link to the manual let me know if that doesn't help
SOURCE: I have a Conair Weight watchers digital scale, how
replace it with 9v lithium battery that you can get anywhere.
http://www.google.com/products?q=+9v+lithium+battery&hl=en&aq=f
SOURCE: Programming CONAIR WW 35 CHA Weight Watcher Scales
Press Set and choose the P-##(used to help you recognise which user, so skip your P-## and go to another number by using the Up/Down keys, once you have selected a P-## press Set to begin inputting details, you can input details with Up/Down keys with Set to confirm an input.
SOURCE: Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
