Am running windows 7 home premium. I followed the instructions to get the new driver but when I plug in the scanner and turn it on, I get a message that it is not recognized and failed to load properly. No what?
The drivers it needs are in Windows\system32\drivers and include usbscan.sys and 2 others. I discovered that I had to run the device troubleshooter until it came across the single image scanner, I let it install drivers and then it worked with the primefilm software. That took hours, but the solution was to let Windows 7 64 bit do a troubleshoot on the hardware.
SOURCE: Computer can't communicate with scanner.
Go to START menu click on devices and printer, then locate and click on add device, and follow the instructions.
Hope this helps you
SOURCE: Trying to use PrimeFilm 1800U scanner on my Dell
Uninstall Presto Mr Photo, image folio & Cyberview, all of which are not Vista compatible. Obtain new scanner drivers from http://www.scanace.com/en/download.php. Also, can use any image editor once scanning complete. Google provide free application called Picasa at www.picasa.google.com.
SOURCE: PrimeFilm 1800u power
Power Adapter:
Output -12V DC /1A
, Input - 100VAC or 240VAC, Frequency: 47Hz to 63Hz
SOURCE: I need a driver for the Pacific Image PrimeFilm
Here you are: http://www.scanace.com/en/download.php
Go there and select the correct printer and operating system and it will provide you with a download link :)
SOURCE: Is there a Vista SP2 driver for a Pacific Image
I see a Vista driver that is untested in Win7 but doesn't have any service pack limitations. This is free to download.
http://www.scanace.com/download/driver/CVXSF/118c/SF_ENG.exe
I hope this helps.
Testimonial: "Thanks a lot Arthur"
Hello, This scanner will not be supported on windows 8, all of our USB 1.0 technology scanner will no longer be supported beyond Windows 7.
Wendy
