Amazon Kindle Wireless Reading Device Logo
Colin Dobson Posted on Dec 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kindle screen is frozen. - Amazon Kindle Wireless Reading Device
honey
Level 3:
Master:
  • Amazon Master 262 Answers
  • Posted on Mar 17, 2018
honey
Amazon Master
Level 3:
Master:
Answers
262
Questions
Helped
320341
Points
1535
Just press the restart button for 30 seconds and turn it off and on for couple of times or you can call the Kindle Support to get resolve your problem for more Kindle Technical Support Registration 877 690 9305
Anonymous
Level 2:
Sergeant:
  • Expert 331 Answers
  • Posted on Dec 29, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
331
Questions
0
Helped
93068
Points
691
Follow the steps for dealing with a frozen Kindle screen on the Kindle Support web pages.
2answers
How to Fix Kindle Paperwhite Frozen on Lock Screen?
Oops, are you troubleshooting the Kindle Paperwhite Screen Frozen problem? Have you tried all the possible ways to solve this difficulty? Not to worry, if the steps you perform don't work, we are here with some fully searched solutions that will help you to overcome Kindle Paperwhite Frozen on Lock Screen. Follow the guidelines step by step to get out of Kindle Paperwhite Screen Frozen matter easily on your own.
Steps To Solve Kindle Paperwhite Screen Frozen In Minutes
Charge The Kindle
A very common reason that leads to Kindle Paperwhite Screen frozen is the lower battery. It can be possible that you are facing screen stuck issues as of the empty or uncharged battery.
So, to let your device work properly you have to charge it first. Hopefully, charging your device will help you to overcome Screen frozen on Kindle.
Uninstall Corrupted File
If you have downloaded a wrong or corrupted file then you are definitely going through with Kindle paperwhite frozen on lock screen as well as scattering issues with Kindle.
Kindly uninstall the corrupted file as quickly as you can do, otherwise, it will cause damage to your device.
My kindle paperwhite is frozen on Kindle start screen and will not respond to any restarts
If your kindle screen is frozen then you can navigate to the below given link. If you still find any kind of issue then take kindle support from experts or call them.
Screen frozen. Push reset screen goes blank and will not turn on. Put in charger and back to the frozen screen.
Try again. Make sure Kindle is charged. Hold down the on button until you see the fire logo. This usually works.
2answers
Frozen screen and now it won't turn off
If your kindle are frozen and won't turn off so, firstly reboot your kindle this is done by pressing the side button minimum 20 to 40 second and screen are blinking so, give the kindle about one minute to start backup.
What to do when Kindle Stuck on the Start screen
Kindle 4 frozen
screen frozen tried everything no luck
5helpful
2answers
My amazon kindle screen is frozen on the right hand upper corner. The rest of the screen is still fine and works but that corner is frozen.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
5helpful
Non responsive (battery is fully charged). Screen has frozen up.
There is a reset button at the bottom (insert paper clip in pinhole). If all attempts trying to unfreeze it fail, you may have a logic board issue. Are you sure the Kindle powers up? Try to power up your Kindle with a different battery. If that fails, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
