Splendide 2000S Vented Washer/Dryer Logo
Anonymous Posted on Dec 26, 2011
Drum doesn't turn
  • Anonymous Dec 27, 2011
    motor is running. I will pull the unit out today and see if the belt is broken or just slipped off. Will further advise later, thanks--Rick
Doug Adams
Level 3:
  • Master 682 Answers
  • Posted on Dec 27, 2011
Doug Adams
Master
Level 3:
Answers
682
Questions
Helped
187350
Points
1917
Is motor running? Maybe a broken belt? If motor does not run at all maybe door switch is not working.
  • Doug Adams
    Doug Adams Dec 27, 2011
    You might also look at the tensioner/ shock adsorber. There is a breakdown of this machine is you copy and paste this link into your browser: http://www.beamalarm.com/foretravel-link...
Mtd4 mistral
Underneath where the motor is,, there is a locking mechanism, which is operated by a cable connected too the lid, check cable hasn't snapped or come off,, it's adjustable also,, may just need adjusting
1helpful
Dryer motor just hums, drum doesn't turn
check belt drum drive? check drum turns at all, it may be stuck.most drums turn with a belt. if it broke it is laying on the bottom of the dryer.didnt u see it??look again.
Drum doesn't turn
What is the model number of the unit?
Dryer drum doesn't spin
If the motor runs and the drum doesn't turn then most likely the belt is broken.
Drum doesn't turn
The usual cause is a broken belt. If the motor is running replace the belt. About $25.00 for the part.
Jul 31, 2012 • Dryers
Siemens xlm1600 drum doesn't turn - motor running - full load of wet washing. Inlet/outlet checked and cleaned - ok. Won't even turn when empty. Whats up?
something jammed between outer drum and inner drum or bearings jammed, if any off these then belt will be burnt Re: Jeff
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 • Dryers
3helpful
2answers
Whirlpool dryer drum doesn't turn. Hear fan motor and gas ignition but drum doesn't move. Tried overide switch on door to verify the drum doesn't move. I am looking for the owner manual but I...
the belt broke,you can buy a kit with the belt,rollers and pulley,change out everything and you'll be good to go.next time send the model number.good luck.while you have the dryer apart,vac out all the dust and lint and if you have a shop vac put it on blow and blow the motor out and clean out the duct that the lint filter slides into,also if your vent line is a long run remove it from the back of the dryer and blow it out with a leaf blower if you have one.
1helpful
Turns on, fills with water, but then won't spin and makes a high pitch squeel. Belt maybe?
While the belt IS a possibility, you should check to make sure that the drum is not out of balance or that it is wedged somehow.
When the drum is empty, try to manually turn the drum. You should only being turning the resistance of the motor and belt; and the internal working of the tub, so it should turn under some pressure. BUT don't put excessive force into trying to turn it! If it doesn't turn with moderate pressure then something has come loose and wedged the mechanism. Which means that the drum system would need disassembled and repaired.
Dryer not working I replaced the Thermal fuse and still not working.
Is the drum turning? If it's turning, then maybe the high-limit thermostat or element is bad. If drum doesn't turn, check lid switch.
Top Splendide Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ADMIN Andrew
ADMIN Andrew
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
