CANNOT GET PICTURE TO FILL SCREEN
If it is a screen setting, wide screen, movie, other setting it may be as simple as that it would be a matter of menu settings. or if it is trying to decipher HD and it is not connected to an HD Reciever then it would not fill the screen.
http://support-us.samsung.com/cyber/popu...
Under picture trouble shooting I hope this helps.
SOURCE: LCD TV Picture
I've seen some of these where some of the cable connectors inside of the set need to be reseated . They have become loose . Or you may have a problem in the video circuit of the set . Good luck
SOURCE: How do I adjust the picture to fill the screen
Does your format button not work or aspect or picture size it may also be in the menu some pictures yo can't change
SOURCE: someone was messing around with
i was going crazy then i finally found a clue on google: hit the setting button on your digital cable remote, go into 'display', change aspect ratio to 16:9, screen size to 'stretch', and output to 1080 or 720 depending on what you have. Were HD channels full screen? If they were they were NOT set properly as above anyway and non-hd channels were black on both side with some having black all the way around on some channels, correct? Hope it helps! I have time warner digital cable and an 52 LG 70 with HDMI...no settings on your tv will fix this if you are in a similar situation b/c its the settting in the digital cable box that need to be re-adjusted.
SOURCE: my new flat screen doesn't fill the entire screen
Look at th remote for 'format', 'zoom', or 'aspect' on the remote control.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series..
MY TV IS A SAMSUNG MODEL NO LN-S2641D
MT TV IS SAMSUNG MODEL NO LN-S2641D AND HAVE TRIED USING THE REMOTE MENU AND SATELLITE REMOTE WITHOUT SUCESS
