Question about Sony Bravia KDL-40S4100 40 in. LCD TV
My sony bravia 40'' TV video in 1 and 2 is showing lock, how can i go about it.
    New Friend:
  • 56 Answers
Try to reset tv from service menu sony service menu display 5 vol+ power from remote and see the reset menu and reset whole tv functions.
Posted on Mar 02, 2012
Anonymous
SOURCE:
mahesh patel
  • 197 Answers
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Posted on Jun 09, 2009
Anonymous
  • 14 Answers
SOURCE: Sony Bravia XBR 40" LCD
First, HORIZONTAL CENTER.
1) Press MENU.
2) Scroll to SETTINGS.
3) Scroll to SCREEN.
4) Go to HORIZONTAL CENTER. Move the picture to the right. Hopefully, the line will go away. Otherwise, there is a problem with the pixels or the signal processor. Call 1-800-222-SONY. Or, http://eservice.sony.com. Have a high-limit credit card handy for out of warranty repairs. Sorry about that.
Posted on Feb 17, 2008
Anonymous
  • 1077 Answers
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
Anonymous
  • 630 Answers
SOURCE: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Posted on Nov 08, 2009
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: i have a sony 40 inches bravia flat screen hd and
Could be the decoder:
1. unplug the TV ans wait a few mins.
2. If you have digital cable box or dish tuner reboot those as well (likely your issue)
What you have is artifacting what that means is tiling garbiling and freezing this happends when the data in the digital stream just stopped hence Frozen.
Try those things rule out your cable tv box first or your sat box, if this is OTA over the air your antenna.
1. Try DVD's if it happends during a DVD you do have a decoder issue if it does not you need to talk to your cable tv or sat operator.
So you got 3 possiabilites here 1. the worse Decoder, 2 cable company or satalite provider, 3 your antenna is in the wroung position.
I sure this will help.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Nov 30, 2009
Testimonial: "i just hope this works"
I have sony bravia KDL-40BX420 TV ,purchased 03 years back.recently got a problem with pictures & colour.It shows pictures with shadow & colours are blured.please give your feedback
I would check the menu settings and reset everything to default. if there are calibration tests in the menu, use them. Try more than one source for video.
May 22, 2014 | Sony BRAVIA KDL-40BX420 40" 1080p 1920 x...
Looking for a table top mount for my Sony Bravia 40" TV (KDL 40V3000). It's no longer available from the manufacterer. Is there a universal mount that will fit?
I would check with MCM electronics who sells nearly 100 different universal mounts for many sets. They have a online catalog.
Dec 02, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
On my Sony Bravia KLV-S40A TV I have a message "VIDEO 1". How do I get it off the screen?
On the original SONY remote press display to remove that---if left on long enough it will actually burn that image into the screen--button on almost any Sony Tv remote will remove or clear it.
Oct 25, 2012 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Sony Bravia screen looks cracked? Is this just a board problem or something more serious?
New screen required as it has been damaged. Probably cheaper to replace the set.
Jun 20, 2017 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
I've tried connecting a Sony DVD player to my TV using Pb Pr V cables. I get a picture, but no sound.
The cable u are using it is the S-video cable?Yes,this cable dosen't support audio.Must used a RCA component cable like R,W cable connected between the tv and the DVD player to get sound.
Mar 14, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia KDL-40S2000 thin vertical line
If the line is present in all inputs and modes, there is a problem with the LCD Panel. The only way to fix it is to replace the whole LCD Panel which is very expensive (usually around $1000+ for 40" Sony). Unless the TV in under warranty, it is usually around the same price for a new TV.
Oct 05, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
DVD is wired to the VCR and does not work
The Sony Bravia should have a number of component inputs, so you should be able to hook up the DVD directly to the TV. The only reason for hooking it up through the VCR would be to record a DVD on VHS... but that's for the birds--VHS is old technology.
Each component input on the back of the TV has a number. You then select to view the component you want by pressing the remote control button to change the display (it should show with one you're on... e.g., Video 1, Video 2, Video 3, etc.).
Dec 24, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL-40S4100 40 in. LCD TV Logo
609 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
