My windows xp load abnormally. I've tried safemode , stil did'nt work, restart from last working configuration, still didn't work. so i wanna run my master recovery disc(packard bell) but my cd couldn't be found from both drives(cdrom and dvd drive). I've ordered another master recovery cd, coz i thought that was a cd problem but it still the same result..drives failed toread my master cd..
I've tried removing battery from my CMOS but still no effect..
what's the best thing to do?
SOURCE: my pc cdrom/dvd drive failed to read my recovery cd
Are you attempting to boot from a bootable disc? A failed drive can cause the other on the bus not to work. Try each one separate set as master or cs (cable select).
try this link:
http://www.fixya.com/support/r5393255-windows_password_recovery
If you have lost
windows password, the best thing for you is creating a password
reset disk.Actually,when you add a password to your pc,the
first thing you should do is creating a disk in case you lost the
password.But how to make a password reset disk after you have lost
the password ? Follow these
You need to prepare:
1:A blank
CD/DVD or USB flash drive
2.A computer which can link to
internet
3.A program called Windows
Password Key
Then let's begin
Step 1.Login to a PC which
can link to internet,Download and install the program from in that
PC
Step 2.Run the program and burn to CD/DVD OR USB flash
drive
Step 3.Turn to your locked PC,insert the newly create CD or
USB to your drive.Reboot the Computer
and then follow the instructions,it is very easy to use.
Lost user password in XP with
networking set-up on HP
The best way to do this is using the Offline NT Password &
Registry editor.
You can download it at the following link:
http://pogostick.net/~pnh/ntpasswd/
This
utility will enable you to reset the password of any user that has a
valid (local) account on your Windows NT/2k/XP/Vista etc. system.
The
link above includes some directions on how to use this utility.
