Is Minolta Magicolor 2200DL compatable with Windows 7 if not can it be used with Virtual device XP and if so how is that set up?
Yes it does work with Windows 7. The way to install it is NOt to run the Magicolor install routine supplied with the printer. Insteda in Windows 7 start menu, devices , add printer, clik on the ADD printer option (at the top) . Windows 7 will then come up with a suggested list of printers including the 2200DL. Ignore this as iot only allows a postscript driver to be installed. Instead choose the I have disk option. get windows to look for the install disk (or install files if downloaded from the QMS site and find the .inf file. Click on this. Windows 7 will then install the up to date Windows print engine files and marry it to the dteails for the 2200Dl details and you will end up with a Windows 7 driver. This works in Windows 7 home premium and professional.
Robindtg
Thank you "iconzap" for answer. I don't know what happen before but after switch on the printer and waiting 4-5 minutes when the printer noisy crack, I can easily print on the printer. I ask you because I seen your answer at similar problem on FIXYA.
Thank you Tom.
