UPGRADE ANY ANDROID PHONE TO KITKAT
METHOD 1:
If you don't want to take any risk and don't want to mess with your phone or computer you can easily upgrade your android to kitkat official look to have some new and best features in android there is lot of android kitkat launcher in the android play-store and here i am going to show you some of best and free kitkat launcher to gave whole new look to your android phone and have kikat experience in any phone which have gingerbread or jelly bean android.
KITKAT EXPERIENCE WITH KITKAT LAUNCHER
KITKAT LAUNCHER
- Download One of the best KitKat Launcher.
- Fully Loaded with all new functions of kitkat.
- All the functions are available free of cost.
- Easily install and have all new kitkat look in your android phone
KK LAUNCHER (KITKAT LAUNCHER)
- Download Another best KK Launcher (KitKat Launcher).
- This is also Fully loaded anf fully free of cost available in android play store.
- Give all new look to your bored android jelly bean.
METHOD 2:
Here is How Upgrade Any Phone To KitKat So lest have a look ant some steps to update your jelly bean android phone to kitkat.
Important Aspects To Know
- Users must have a proper backup of your data, apps and settings
- Ensure that the device is fully charged
- USB Debugging must be enabled
Odin works only in Windows. Users of other platforms like Linux OS (such as Ubuntu) or Mac OS should use CrossOver Utility to run Odin in their OS ' Or There is some more tools to flash kitkat rom find matched for your android or comment down and let me find and then tell you
Note : The users must proceed at their own risk while trying out the manual installation
REQUIREMENTS :
- At-least Have 1 Gb Ram Mobile phone.
- Al-Least Have Quad Core mobile Phone.
- With Fast GPU.
- And Of-cause An Android Phone
HOW TO INSTALL CUSTOM KITKAT ROM IN ANY ANDROID
- First of all you need to find update file for your android phone that you are using. you can comment down if u can't find files for your android phone i can find for you .
- Download Custom Rom or any one you want based on Android 4.4.2 KitKat and Google Apps for Android phone your computer
- Connect your android to PC via USB and copy the ROM and Google Apps packages to the root folder of your handset's SD card without extracting them.
- Disconnect USB and turn off your phone.
- Get into the Recovery Mode by pressing and holding Volume Up, Home and Power buttons together
- In the Recovery Mode, perform a factory reset by selecting "wipe data/factory reset." Use the Power button to select options. Now, perform a cache wipe by selecting "wipe cache partition."
- Now wipe the dalvik cache as well. From CWM recovery, go to "Advanced" menu and then select "wipe dalvik cache."
upgrading is not a common issue. Download the firmware from the support page on cruz's website. Ensure it's named properly. put it on the sd card. PLUG IT IN first. then do the power and volume button at the same time until it flashes white when lines of code start coming. Do not let go until then it should work. If it doesnt redownload the firmware and try again (making sure it has the proper name). You will get 2.2.
