Remote code I have a Dish Network remote. The remote that came with the Aspire DVD Player is not working. Is there a code so I can program my Dish Network remote or universal remote so i can operate it?
Hi my nameis Mike Houston of DISH Network and I see you need the code for the Mintek DVDplayer. We currently do not have a code that goes to the DISH Network remote, wedo have what we call a Power Scan to program the DISH remote to the DVD player.I will send the link to help with these steps, http://www.dishnetwork.com/SupportSection/power-scan-instructions.
Hi my nameis Mike Houston of DISH Network and I was going over your post and see whereyou want the codes to program the DISH remote to the Emerson DVD/VCR. We do nothave the three digit codes to enter however we do have what we call a PowerScan and it will allow programming the remote to the Emerson player, I willsend a link to help with these steps. http://www.dishnetwork.com/SupportSection/power-scan-instructions
Hi my nameis Mike Houston of DISH Network and I see where you want to set the DISH remoteto your GPX DVD player. There are no codes to put in manually but we do have aPower Scan that will go through all the codes and allow the programming to theDVD player, I will leave the link to help with these steps. http://www.dishnetwork.com/SupportSection/power-scan-instructions
Hi there! In order to be able to provide the definite codes that will allow you to program your remote to your Magnavox Blue Ray DVD player, I would need the type of remote that you have- this can be found on the back of your remote, it would be displayed as something along the lines of 3.0, 4.0, 5.0, etc. To obtain a few codes that will likely allow you to successfully program the remote I used 5.0 because it is a common remote that is used with quite a few of our DISH Network receivers. The codes you can try for your DVD player would be, 829 (most successful) if not then please try the following, 685, 533, 554, or 556. After trying those codes if your attempts are still unsuccessful you can also check the manual that came with the DVD player from the manufacturer or just contact us here at DISH Network - although I do know sometimes the remote codes can be located in the manual. Hope the codes help & work for you!
It's been a few months, so I am hoping that you were able to find the code. But if not, below is a link that will not only give you the available codes, but also walk you through programming the remote to the player.
Sorry to hear about the original remote, we would be happy to help with getting your DISH remote programmed to your Curtis DVD player. Here is a list ofcodes that should address your DISH Network remote to your Curtis DVD player: 678, 679, 683, 585, 592, and 594. Start by pressing and holding the DVD/VCR button located on the top of the remote until allthe mode buttons at the top of the remote light up, then release. Use thenumber buttons to enter one of the codes for your Curtis DVD player, thenpress the pound (#) button. If the code entered is valid for the remote, the modelight flashes three times.To check that the code works try several different functions on the remote tomake sure it will properly operate your DVD player. Keep in mind that somecodes may not be compatible with your equipment. If this is the case, pleasetry the other codes listed for that device until you find one that iscompatible with your equipment. We hope this helps and thank you forbeing a valued DISH Network customer!
Phillip Chang DISH Network Customer Service Representative
We would be happy to help you with getting your DISH Networkremote to control your DVD player. Start by holding down the TV button located on the top of your remote until all mode buttons come on, then release. Use the number buttons to enter thecodes for your Memorex MVD2022 DVD Player; here some of the codes we currently have: 549, 554, 566, 789, 516, and 533.Press the pound (#) button after code has been entered. To check that the code works try several differentfunctions on the remote to make sure it will properly operate the DVD player. Keep inmind that some codes may not be compatible with your equipment. If this is thecase, please try the other codes listed for that device until you find one thatis compatible with your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
I had rca remote that did not recieve ir signals but rf signals instead. Check online with rca or in owners manual for what type of signal factory remote sends. The dvd player I had was 5 dvd and that was the case. Dish might have an option like direct tv where you can program rf signals as well. Call dish network support or look online
It's kind of silly but I just pushed the VCR mode button, pressed the power on and off mode button & pressed the up button until the remote found the code. Took awhile but it finally worked.
