Computers & Internet Logo
Anonymous Posted on Dec 31, 2011
Need a new activation key code for windows xp pro
It's a custom built computer not a brand name computer. The current installation has reached its limit for the key code iam using.
Catalin Turcu
Level 3:
  • Master 4,924 Answers
  • Posted on Jan 01, 2012
Catalin Turcu
Master
Level 3:
Answers
4924
Questions
0
Helped
1231313
Points
13383
I suggest to reinstall it ..and use a windows xp sp3 to do that ..If you have no ..just download an image and burn it on a disk using nero ..and will do the job ..
use utorrent to download this image ..and burn it with nero ..on a cd ..before you use it ..Just double click the image file if you have nero in the system ..or download nero and install it first ..from here ..(use the key for it )
nero _http://www.mediafire.com/?yznzmdonjgm
utorrent - http://www.utorrent.com/
windows xp - http://thepiratebay.org/torrent/6892530/Windows_Xp_Sp3_Corporate_student_edition_December_2011
This is a genuine windows with no key needed..The key is already loaded in the image and will work just fine .
Install utorrent first ..and download the image with it ..(Just click on download this torrent and use the utorrent program automatically ..so install it first )
after you have the image downloaded with success in the hard drive ..just install nero 7 ..and restart ..and insert a blank cd ..and double click the image to start ..It will open nero automatically ..select a low speed and burn it ..It will end up in a boot-able disk
I hope I was clear enough ..but if you have any questions just ask ..
How to change a product key that is already activated on windows xp professional?
Click on Start and then Run.
  1. In the text box in the Run window, type regedit and click OK. This will open the Registry Editor program.
  2. Locate the HKEY_LOCAL_MACHINE folder under My Computer and click on the (+) sign next the folder name to expand the folder.
  3. Continue to expand folders until you reach the HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\Current Version\WPAEvents registry key.
  4. Click on the WPAEvents folder.
  5. In the results that appear in the window on the right, locate OOBETimer.
  6. Right-click on the OOBETimer entry and choose Modify from the resulting menu.
  7. Change at least one digit in the Value data text box and click OK. This will deactivate Windows XP. Feel free to close Registry Editor at this point.
  8. Click on Start and then Run.
  9. In the text box in the Run window, type the following command and click OK.
    %systemroot%\system32\oobe\msoobe.exe /a
  10. When the Let's activate Windows window appears, choose Yes, I want to telephone a customer service representative to activate Windows and then click Next.
  11. Click the Change Product Key button at the bottom of the window.
    Don't worry about filling anything out on this screen.
  12. Type your new, valid Windows XP product key in the New key: text boxes and then click the Update button.
  13. You should now reactivate Windows XP by following the instructions on the Activate Windows by phone window which you should now be seeing or via the Internet by clicking the Back button and following the instructions on that screen.
    If you'd rather postpone activating Windows XP until a later date, you can click the Remind me later button.
  14. After activating Windows XP, you can verify that activation was successful by repeating steps 9 and 10 above.
    The Windows Product Activation window that appears should say "Windows is already activated. Click OK to exit."
How To Change the Windows XP Product Key
3answers
The product key for my windows xp pro doesn't work
have you reformatted your computer? are you getting an invalid product key or error in activating windows?
reason: you may have used your product key several times and reached the maximum number of times you can use it.you can call 1-800-936-5700 and validate your product keys. if found legit, you can always request for a new product key for free or for $10.
1helpful
I have 3 operating systems installed so i need to lose two of them dont ask cos i dont know how they got there
I recommend you do a clean reinstall XP Pro using the Windows XP Pro installation CD. Delete all the partitions and create a new partition.
This is generally how your format the hard disk and install Windows.
First you need a Windows XP or Windows Vista installation CD and the product installation code, which is printed on the Windows label on the bottom of your laptop.
Boot up with the Windows installation CD start and follow the instructions to install Windows.
Next Delete the existing Windows partition.
Next Create a new partition.
Next format this new partition - Format the partition in NTFS not a quick format. This will prepare the Windows for a clean install.
Next create a User(name) and company name (normally Home is all you need).
Further into the installation, you will be required to put in the Installation code.
During the final stages of installation you need to create an User or Users that will use this computer.
When you finished installing Windows you need to install the laptop's device drivers. You need to use a computer with Internet access to download these drivers from the laptop manufacturer's WEB site and install these drivers on your laptop.
Next connect a LAN cable to the LAN port from your computer to your DSL or cable modem and you need to Activate the Windows installation on the Microsoft WEB site.
Next up need to upgrade Windows from the Microsoft WEB site including Service pack.
Next you need to install your programs
You can download the device drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows of the drivers for your Windows operating system. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Need anew activation key code for windows xp pro
Go to http://windows.microsoft.com/en-GB/windows/help/genuine/product-key and use the Microsoft Product tool which will guide you through the process to purchase a new product licence code.
I want a legal product key for windows xp professional sp2 so I can register it with microsoft
Hello. If your computer has a windows XP Pro sticker on it you may be able to call Microsoft and validate your operating system if it is ligitamate, or buy an operating system disk on ebay for your brand of computer. Any Dell XP Pro disk will work with a Dell computer having a Dell XP Pro sticker, and so on for other brands, as long as your sticker has your computer brand on it. If you have a sticker without a brand name or no sticker at all you'll probably have to buy a retail disk.
These directions may be helpfull.
How to activate Windows XP by phone
loadTOCNode(2, 'summary'); To contact a Microsoft customer service representative to activate Windows by phone, follow these steps:
  1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Activate Windows.
    Or, click the Windows Activation icon in the notification area.
  2. Click Yes, I want to telephone a customer service representative to active Windows now.
  3. Click Read the Windows Product Activation Privacy Statement, click Back, and then click Next.
  4. Follow the steps in the Activate Windows by phone dialog box, and then click Next.
    Note The number appears now and differs based on the location that you select.
  5. When activation is completed and you receive the following message, click OK. You have successfully activated your copy of Windows.
1helpful
3answers
Having problems activating my windows xp activation key
When you decide to activate your Windows XP, do it by phone rather than online.
If you have a problem entering the codes, you will be directed to a live person who can help you through the process.
Have custom built computer mo.bo.mv43v intel pent 4.15 processor
as it is a custom built computer the xp install would have been from the original disk.... if you call microsoft they will help you activate it.
2helpful
2answers
Formatting and reintallation of windows XP
Just Put the XP CD in your CD Drive and restart your PC..you ll get a screen immediately after your PC restarts i.e. press any key to boot from CD..press any key in your keyboard...after some time.u ll get a screen showin whether new or upgrade required...click new...then u ll get a screen to setup in which drive..select a particular drive it ll format...follow the instructioons thereafter..It s just easy..
Please rate my suggestion
The dest top OS Win XP crashed reinstalled and to be keyed
Here's How:
  1. Click on Start and then Run.
  2. In the text box in the Run window, type regedit and click OK. This will open the Registry Editor program.
  3. Locate the HKEY_LOCAL_MACHINE folder under My Computer and click on the (+) sign next the folder name to expand the folder.
  4. Continue to expand folders until you reach the HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\Current Version\WPAEvents registry key.
  5. Click on the WPAEvents folder.
  6. In the results that appear in the window on the right, locate OOBETimer.
  7. Right-click on the OOBETimer entry and choose Modify from the resulting menu.
  8. Change at least one digit in the Value data text box and click OK. This will deactivate Windows XP.
  9. Click on Start and then Run.
  10. In the text box in the Run window, type the following command and click OK.
  11. When the Windows Product Activation window appears, choose Yes, I want to telephone a customer service representative to activate Windows and then click Next.
  12. Click Change Product Key.
  13. Type your new, valid Windows XP product key in the New key text boxes and then click Update.
  14. If you're taken back to the previous screen and prompted, choose Remind me later.
  15. Restart your PC.
Tips:
  1. Not comfortable making registry changes? Luckily there is another option if you need to change your Windows XP product key code. The Magical Jelly Bean Keyfinder, a popular product key finder program, also has the ability to easily change the Windows XP product key. If the registry makes you nervous, this is a great alternative solution to changing the Windows XP product key code manually.
P.S.: If this information was helpful, please rate this solution.
Grand Canyon Tech
Grand Canyon Tech
