SOURCE: oil come out the air cleaner
Too much crankcase pressure or the breather pipe is split/dosconnected. The crankcase breather goes into the rear of the air filter and the crankcase gasses are drawn in to the cylinder with the gas/air mixture and burned
SOURCE: 2009 harley night train oil change instructions
i am not being a wiseguy, but if you buy the repair manual from harley, you'll have very easy to follow guides. the manual is $50. if that doesn't help cause of the price e-mail me and i'll walk you thru it..good luck and ride safe.
rande
SOURCE: Harley Davidson Ultra classic handlebar replacement
1.cover the tank with towls beachtowls 2.remove switches,unbolt both ,clutch and front brake from bars,leftside grip pry under it with a flat crewdriver and spray under it with hairspray and turn on it to make it come off, right side loosen the bars and move them so when you loosen the rightside it can come right off.unbolt the bars from center of the bars
SOURCE: correct torque for rear axle nut on 1997 harley davidson fat boy
Harley manual says 60-65 ft lbs... do NOT exceed this or wheel could seize
