Samsung SWA-4000 Logo
Posted on Oct 06, 2008
SWA-4000 doesn't adquire signal of HT-TX500 Home Theather
I have a Swa-4000 and i'm trying to connect it to a ht-tx500 home theather, but the signal light of the wireless module flashes for a while and then goes to stand by. I've already tried the way described in the manual but without any effect.
  • 4 more comments
  • alisonash Oct 10, 2008
    I have the same problem! Turn off main unit, press 0-1-3-5 on remote then press the button on the wireless unit. Link flashes for several seconds then goes back to standby. Rear unit says REAR CHK
  • Anonymous Oct 13, 2008
    Yes, I have the same problem. Ive tried turning off all other wireless devices in the house as suggested by Samsung Support. I even returned the first SWA-4000 in replacement for another and still find the blue light flashing several times and cant pick up the transmitter. Samsung support couldnt even suggest anything apart from they have the SWA-3000 which works fine. Not much of a sales pitch. Any suggestions?
  • poohone Oct 19, 2008
    i have exactly same problem!!! did u finde any solution???
  • Anonymous Feb 28, 2009
    I have the same problem. I just bought a HT-X715 and a SWA-4000 but the wireless connection does not work. I have made as indicated by the user manual but the receiver module goes to standby ;-( Thanks for the helps ;-)
  • Anonymous Mar 11, 2009
    Thanks guys! with your help I could manage to make this work. The user manual was WRONG and the product wasn´t even listed on the local site!!!??? Shame on SAMSUNG. Will think twice before buying another stuff from this company....
  • Anonymous Jun 21, 2013
    i have the swa 3000 and i had connection first night i set it up..next morning when iturned it back on..i couldnt establish link...blue light wont even light up..when I hold remain on remote i see red light flash on receiver but it still wont make a connection.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 30, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3722
Points
11
I was having poor audio from the back speakers and didn't even know it; intermittently I'd hear them jump in volume, so myself being a little adventurous, decided to push the ID set button on the back, totally losing my ilnk... after digging and playing, I figured it out:
1.) Turn off the Head (main) Unit 2.) Power on the wireless receiver, being sure it is away from routers, other BT devices, etc. 3.) Push the "ID Set" button on the back of the wireless device and hold it until the lights on its front panel flash. 4.) Point the system's remote control at the Head Unit and punch in 0135.  Its light should turn from red to blue. 5.) Perform step 3 again. 6.) Power on the head unit.
Should link up.
Might be some redundancy there, but it works :)
Also I found that after a few cycles It seemed to work better (perhaps cycled to a better channel?)
Anonymous
Level 1:
  • Posted on Nov 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3722
Points
Hi...im not sure how it happened...what i did was i pressed 0135, the main unit lit up and i pressed the id set or something like that on the back of the wireless reciever.....well the main unit should be back to red and once i pressed the id set i accidentaly pressed the power button so the main unit turned on...then i waited for the wireless reciver to boot up and worked.....
Anonymous
Level 1:
  • Posted on Jun 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3722
Points
I had the card in upside down. Unfortunately, it fits both ways, but the slanted edge faces left).
Anonymous
Level 1:
  • Posted on Apr 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3722
Points
Eteindre le module sans fil SWA-4000.
Eteindre le Home cinéma.
Faire un reset, par appui sur le " id set" au dos du module sans fil c'est à dire SWA-4000.
Allumez et cela devrait fonctionner.
C'est comme ça que moi j'ai réussi avec mon home cinema
Merci.
Thierry de LYON
2helpful
My SWA-5000 is not connecting to my main unit, which is a samsung blu-ray home theater system. I have already tried what it has said on the manual, but it still wont turn on, it is just on standby. Please...
start with the main unit turned off. Press and hold the button on the back of the swa-5000 module until the light on front starts blinking fast. Then point the remote at the main unit and press 0-1-3-5-ENTER. The standby light on the main unit should turn off then back on. Turn on the main unit and it should find and link with the wireless amp.
2helpful
Will a swa 5000 tx card fit a ht-tz225 home theater ststem
Unfortunately it would appear not. I just bought an SWA 5000 for my HT TZ 225 home threatre system as it would seem the SWA 4000 has been discontinued - the HT-TZ225 refers to the SWA 4000 doesn't it.
The tx card that accompanied the SWA 5000 was too big and did not fit in the back of the DVD player so I will have to return this to the retailer and keep looking for an SWA 4000 . . .
Unless anyone has another solution.
8helpful
I'm having problems getting my swa-4000 system to work tried the code and holding down the reset button i have an ht-x715t system and the tx card is in right any idea's thanks
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
1helpful
How do i hook this up Samsung HT-WX70 Theater System with Wireless Speakers
1. Connect the front left, front right, center, and sub woofer speakers to the back of the home theater system.
2.
With the home theater system off, insert the TX card into the TX Card connection (WIRELESS) on the back of the home theater.
Important:
Make sure to insert the TX card with the slanted portion of the card facing left.
3. C
onnect the rear left and the rear right speakers to the back of the SWA-3000.
4.
Plug the power cord of the SWA-3000 into an electrical wall outlet, and then switch the power switch on the back of the SWA-3000 to [ON]
Hope this helps!
3helpful
Hi, I have Samsung HT-X50 connected with SWA-4000. It was working fine, then for somereason I had to remove and reinsert Tx card. After doing that SWA-4000 is not connecting to HT-X50. Blue light blinks...
You have to reset the connection:
Hope this helps!
1helpful
Dvd home theather system
The audio amplifier IC are fried and need to be replaced
5helpful
2answers
Samsung HT-TX500 region free
hi there
i live in Thailand and just made my HT-TX500 region free,
this is what i did
your dvd must be off with no dvd inside
push power on wait til no disc come up then push enter
then push 84269 then push enter then wait for the dvd to turn off
wait 5 mins.then push power on and that worked for me
Wireless speakers
Google "Samsung SWA-4000" The HTz310 is wireless "ready" only. You'll need to purchase this unit for about $100 to make your (Rears only) wireless.
27helpful
6answers
Samsung SWA-4000 Wireless connection problem - Not connecting with main unit
I have had the same problem with the wireless unit and thought the same, it didn't work. The way to fix this is simple. You need to do the 0, 1, 3, 5 on the remote and turn on the home theatre system on the main switch on the front panel (as I was doing this on the remote, and it was failing). The blue light should then stay illuminated. If not just switch the main on/off button again, and it shoud work.
when you turn it on, hold the power button until it has fully loaded
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
