When I put media card in, is not reading. Was working fine till now. Do they fail at times? Any solution other than replacing it? How would I identify which card and part number I would need?
SOURCE: No memory card will work in my Coolpix camera
Nikon has tested the following cards and approved their use in the Coolpix 3200:
SD memory cards:
SanDisk 16/32/64/128/256MB
Panasonic 16/32/64/128/256/512
Toshiba 16/32/64/128/256MB
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
Multi Media cards (MMC) are not recommended and should not be used.
SOURCE: Dell Inspiron E1505 internal memory card reader
Have you tried dell's website for any drivers. If there are, reinstall them and see if that fixes it.
SOURCE: Ejecting Memory Stick Pro Duo card out of notebook card reader
I had the same problem, and a little tape and MacGuyvering fixed it!
http://lloydandlauren.com/2008/11/21/getting-a-memory-stick-pro-duo-out-of-an-acer-aspire-one
SOURCE: HP Pavilion ZD8000 Digital Media Reader Issue
Try updating you drivers for your digital media reader. Also check your dcos to see if the DMR will read a 2GB card
SOURCE: Dell Inspiron 1525 Memory Card Reader Compatibility
There is no big differece between the two. Both of those can work on your DELL memory card. Cheers!!
