When I put media card in, is not reading. Was working fine till now. Do they fail at times? Any solution other than replacing it? How would I identify which card and part number I would need?
SOURCE: No memory card will work in my Coolpix camera
Nikon has tested the following cards and approved their use in the Coolpix 3200:
SD memory cards:
SanDisk 16/32/64/128/256MB
Panasonic 16/32/64/128/256/512
Toshiba 16/32/64/128/256MB
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
Multi Media cards (MMC) are not recommended and should not be used.
SOURCE: Dell Inspiron E1505 internal memory card reader
Have you tried dell's website for any drivers. If there are, reinstall them and see if that fixes it.
SOURCE: HP Pavilion ZD8000 Digital Media Reader Issue
Try updating you drivers for your digital media reader. Also check your dcos to see if the DMR will read a 2GB card
SOURCE: Dell Inspiron 1525 Memory Card Reader Compatibility
There is no big differece between the two. Both of those can work on your DELL memory card. Cheers!!
SOURCE: won't read memory card
i hvae had this happen many times... ok this is what you will need to do. take the memory card out and look at the little brass things and clean them with something thats cotton. repeat this till it reads. i hope this will help.
