UH71009 quit spinning, caught on a throw rug
SOURCE: hoover eite rewind vacuum has blocked airflow, how do i fix?
Is there suction at the end of the hose, if not then the blockage is in the hose, unhook the hose and dig out the debris, if hose isn't blocked, then clean out the filters, if they get clogged, then air can;t flow thru them and you won't have suction. If you have suction at the end of the hose, then it is clogged down in the nozzle asm. there is an inlet by the brush roll and it comes up to where the hose plugs into. Clean the clog out.
SOURCE: Changing the belt
I'm not familiar with that model, as it is fairly new to the market, but the previous models had a plastic plate that covered the roller. There are two clips that must be depressed as you gently pull the plate away from the machine. This will allow the removal of the plate so that the roller can be removed and a new belt installed. This is a new model, so you must have the manual still. You can also check www.hoover.com for more instructions and last time I checked, they had a manual download feature available.
SOURCE: My Hoover Deluxe Rewind Elite
When you are saying "today it will not work" do you mean the motor runs, but the unit will not vacuum, or are you saying nothing happens when you try to turn it on?
If the motor run's, the belt probably broke. You will need to remove the bottom of the vacuum part that rolls on the floor, get a replacement belt, and install. Check your owner manual for directions and belt part numbers.
i had the same issue, but with a little time and a screwdriver, i got my vacuum working like new.
First, remove the bottom cover where the brush is located. Once the cover is off you'll see the vacuum inlet hose just behind the brush. Clear out any debris you find in there.
Second, on the back of the unit, where the attachment hose connects to the vacuum remove the three screws and clean out any debris you see in there. (dont be afraid to get your hands dirty)
hope this helps!
Country Music Guy
SOURCE: Automatic Cord Rewinder is not rewinding anymore
With the cord pulled out, the rewind spring should be very tight.
The mechanism may just need lubricating, or there is a worn or broken part preventing the spring from retracting the cord, or the spring is loose/broken.
