Had Convergence problem, replaced the STK 392-110's on my Toshiba 42H81, adjusted convergence per service manual and picture looks good, All the inputs work except the OTA ant1 & ant2, just get a blank screen. Whats weird is that when I use the POP mode, the pip on the right is visible but the left is blank. Try to swap but it only switches on the right pane, nothing on the left. Also, in service mode, the "Block: sub main" is red when the diagnostic menu is run. Anybody has an idea as to what is going on? Do I have to make an adjustment in the service mode to slove this?
SOURCE: Sound but no picture in PIP
You mention that the unit is 2 months old. It should be under warranty and should be covered by the store you purchased it from or the manufacturer. If you or any unauthorized person works on it you will void the warranty and besides that's what you paid for when you bought it. Have it looked at by the appropriate warranty person or facility.
SOURCE: just got an antenna to pick up local HDTV
According to the user's manual on page 16, press Menu and open the Setup menu. Highlight Installation and press Enter. Open the Terrestrial menu and highlight Input Configuration. Select the ANT1 or ANT2 (whichever the antenna is connected to) and select input source Antenna [not cable]. Highlight Done and press enter. Now rescan your channels. If you still get nothing, try relocating your antenna to a better place. Digital TV is highly dependent on line of site signals. So if you are in a mountainous region or surrounded by a lot of high rise buildings, you may not receive a good enough signal to register channels on your TV.
