I turn the wii on with the power button on remote just fine but when i need to select a game from main menu on wii . the hand cursor just does not show up , and ive synced the wand many times. but it has only failed. so now i cant select anything on the wii menu to play , due to hand cursor not appearing need help.
SOURCE: i have 2 nyko wands
ok you will need to synchronization.Press the power button on the wii conosle to turn it on remove the battery cover on the backof the remote.Press and release the SYNC. button inside the cover.the player leds will blink.Open the fornt door on the wii console press and release the SYNC.button on the inside of the compartment. when the player LED blinking stop connection is complete the LED that is iluminated indicates the player number, THAT IS IT
SOURCE: I have one nyko wand and one wii want for my new
On the Wii menu, if you press home button, and click "Wii Remote Settings" then "Reconnect" it will enable you to connect wiimotes by pressing 1 and 2 simultaneously. Also some games, Wii sports for example, allow you to use one controller for two or more people.
SOURCE: I have exactly the same
1) Open the battery compartment and there should be a small circular red button.
2) Next to the Wii's SD storage area there is a rectangular square button.
3) Hold down the red button on the controller and the red button on the Wii until the light on the controller stops blinking.
Sometimes it can take multiple tries to "sync" the controller with the Wii. Keep trying until the lights stop blinking.
