Question about LG WM2688H Front Load Washer
Thermistor lg wm2501hva
Getting a tE error code.
5 Suggested Answers
6ya staff
SOURCE:
Richard Lew
  • 489 Answers
SOURCE: Thermistor for LG WM2688H
Treegirl,
It's not an easy job to do.
You will need to remove the top panel, then remove the control panel and then the front panel to gain access to the thermistor.  The part is not available to the public and requires an authorized service tech from LG to take care of this problem.  You will need a special tool to remove the front door seal spring clamp.
But you can call customer service @ 800 243 000 and see if they can transfer you over to parts.  Just give them the model and serial # and see if they would be willing to sell you the thermistor part.  You will also need the door seal spring clamp removal tool to make the job easier.
What city do you live in??
Good luck.
Posted on Jul 08, 2008
Chris Perkins
  • 5 Answers
SOURCE: LG Tromm washer WM2688HWM tE error code. Very easy
LG Tromm Washing machine te error. The manual says to call for service. Not much help there. The reason for the error is the thermistor circuit (resistive element that becomes less resistive as it increases in temperature). The thermistor acts as a heat sensor. In many cases, the error occurs because the wireing harness is too tight at the bottom of the drum and one of the wires in this circuit becomes disconnected with all of the movement of the drum (unbalanced load, normal cylcing etc).
1. Unplug the washing machine from the wall. The thermistor circuit is at line voltage (110 in the U.S.) and it will bite! So do this first before proceeding.
2. Move the washer out so you can get access to the back of it.
3. Remove the stainless panel (the one that is not painted, it is large (aprox. 16x18 inches). It is held in place by 4 phillips screws.
4. Locate the thermistor connection block near the bottom of the machine, at the center of the wash drum. It is the small white connector that has two wires running to it. One wire is dark blue, the other is light blue. Insure that neither wire has pulled out of the connector. If either of them have, repair the connector and provide enough extra wire ( aprox. 2") to provide cable relief.
5. If the cable connector and wires are ok, there are other solutions here that recommend either cleaning or replacing the thermistor.
Good luck to you.
Posted on Aug 04, 2009
milten1
milten1
  • 1304 Answers
SOURCE: Replaced the thermistor on the lg washing machine
sometimes these
have lockouts,
try reseting the eprom
there is two ways,,,
unplug it for ten minutes
or push and hold the pause button for 10 secs
depending on your model this should work
but not knowing the exact model i cant be more help ful but i do hope this saves you 200
Posted on Oct 19, 2009
Anonymous
SOURCE: LG WM2277HW Thermistor (tE) issue
To be more specific, unplug unit. Behind the machine are two plastic kick plates, remove to slide off the top. Once off, two top self tap metal screws and one screw behind panel wall, remove. Remove two detergent screws. Lift electrical panel and set on top of machine. Remove four top screws. Bottom drain has one screw in front, take out plastic cover and one screw in back. Take off rubber by opening door. With a screw driver, prey and lift up the brass spring ring and remove. Then the front panel should slide up and out. Be careful because electric wire is still connected, move to the side of unit. You will then be able to find the thermostat. Unplug and replace, you will need to use the same rubber bushing. Took me an hour, I’m not an appliance repair guy.
Posted on Feb 09, 2010
What does the code te on the LG Tromm washing machine mean?
The TE error or fault code is to indicate a defective water temperature sensing thermistor. The thermistor cannot be repaired and will have to be replaced.
Sep 07, 2014 | LG Washing Machines
Error code te
There is a problem with the thermistor (tE - thermistor error), it must be replaced as it is not repairable.
Mar 11, 2014 | LG WM-2277HW Front Load Washer
TE CODE
TE is thermistor error. it is located on the fill valve. recommend replace
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | LG 3.7 cu. ft. Front-Load Washer - WM2240C
Error code te for lg tromm front load washer wm2496hsm
The TE error code is a Thermistor error. Replace the thermistor and you should be good to go.
Feb 29, 2012 | LG WM-2032H Front Load Washer
Getting a "te" error code -- a heating issue?
I had the tE or te error (an L with a line through it) error on my LG front loader and my local appliance store sold me the thermistor for $7. I layed the unit on its side and accessed the thermistor through the bottom. It plugs into the bottom of the tank. Blue and white wires. No screws and 1 tie-wrap. (Leave the rubber grommet in - just pull the thermistor rod out.) Works like a champ!
Jan 05, 2011 | LG WM2487H Front Load Washer
Te code is showing up. how do i fix this
Sorry to read about your problem, I hope this helps you out.
The te code means a defective thermistor. but thermistors rarely fail in LG washers.
The most likey cause of the "te" error is:
1) Loose wiring at the control panel (directly behind the CYCLE SELECTOR KNOB)
2) Broken wire at the THERMISTOR (located at the bottom /front of the tub)
Test the washer. If the "te" error still occurs--it will be neccesary to remove the FRONT PANEL as well (two sets of special plier-type tools are needed).
Inspect the THERMISTOR closely--with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Malfunction code tE
TE error code stands for thermistor error. You have to remove the front panel and ohm out the heating element. If you have continuity most likely it will be fine. There is a thermistor located next to the heating element that will probably need to be replaced. LG's are the only machine besides GE ref's that I have ever seen thermistors go bad on. There is probably an ohm reading you should get through the thermistor but unless you have an analog meter or a fluke most standard digitals wont read into mega-ohms. Removing the front panel is model specific. But i can tell you the spring around the front boot (drum gasket) needs to be removed and there will be some hidden screws at the bottom by the pump where the access panel is located.
Hope this helps _MJ_
Jan 31, 2010 | LG WM-2277HW Front Load Washer
LG Tromm washer WM2688HWM tE error code. Very easy to remove and replaced the thermistor, BUT still, it's not working, tE error code still there. ????????????
Good luck to you.
Jul 17, 2009 | LG WM2688HWM TROMM SteamWasher
Lg rom reads error code te
TE Error Code = Heating Error - Thermistor failure
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 21, 2009 | LG WM-2277HW Front Load Washer
LG WM2688H Front Load Washer Logo
243 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
