Dryers Logo
Posted on Oct 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
My dryer will turn off after a few minutes whenever I try to dry my cloths in a heat mode, but it runs fine when I use the air dry only mode. It doesn't matter if I use the timer mode, or More Dry/Less Dry Mode; it still turns off.
This is a Gas Dry, Whirlpool Gold, Ultimate Care II Senseon model.
  • pfyrman1 Oct 08, 2008
    Yes, The it will turn off, eventhought the timer shows that there is time left. 10, 30 and even 60 minutes left to go. FYI, the Heater does work.
  • john gagnon
    john gagnon May 11, 2010
    do you mean the whole dryer shuts off
john gagnon
Level 3:
  • Master 943 Answers
  • Posted on Oct 08, 2008
john gagnon
Master
Level 3:
Answers
943
Questions
Helped
324217
Points
2163
HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
I have a Whirlpool duet gas dryer model WGD9400SUO. I can hear the heat turn on but it no longer stays on.
Please make sure that you've removed all of the lint from your dryer prior to every cycle. Next, try to see if the varying the load size effects whether your clothes are heated or not.
If all else fails, please schedule an inspection by Whirlpool by calling 1 (866) 698-2538. Thank you.
1helpful
Samsung dryer in cool down mode in all settings
Check all heating components. If they all check out good, then most likely a control problem
What causes my gas dryer to heat and the flame goes out
Try using timed dry insted of sensor dry if runs ok you need aew sensor strips. also make sure dryer vent is clean.
Ge dryer dcvh515efoww runs on air dry, but when set on any heating cycle, it runs for a few minutes and then it turns off on 00
it is over heating you might have unplugged a wire to the thermostat when you had it apart or the thermostat has went out.
Mar 21, 2014 • GE Dryers
3helpful
2answers
Whirlpool Tumble dryer low heat, taking three cycles to dry one load
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
My dryer takes forever to dry anything and often times will not turn on when i press start after it's been ran for a 70 minute cycle but will turn itself on after sitting for awhile my dryer is
2answers
Whirlpool dryer model LER7646EQ1
Thats what it's supposed to do hopefully the clothes are coming out dry. The dryer has both thermal sesors and fuses that tell the dryer when to heat up and when to cool down. So yes the heating element will come on and go off multiple times in a cycle.
2answers
Whirlpool Dryer not heating
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
9helpful
This can be due to malfunctioning of any of these 4 devices..
1)Heating element
2)Thermal fuse
3)Thermostat
4)Timer motor
For more info and troubleshooting checkout this link..
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Top Dryers Experts
john h
