When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter.A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Type the printer IP address into the address field of your Web browser.
Note: If you do not know the IP address of the printer, then print a network setup page and locate the IP address
in the TCP/IP section.
Click Reports.
The following reports may be viewed from the Embedded Web Server:
Reports
Device Statistics
Device Settings
Device Information
Profiles List
Printer Server Setup Page
If new toner was installed and it prints blank pages, please try to print a menu settings page to determine if the problem is part of the printer or an issue external to the printer.
If the menu settings page prints correctly, the source of the problem is external to the printer. To find out if the problem is only with a program, try printing from a different software program. To find out if the problem is only with a particular computer, try printing from a different computer.
If the menu settings page is blank as well, this will narrow the source of the issue to a part on the printer. Please contact Lexmark Technical Support for further assistance.
We would like to know more about the flashing lights you're referring to. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
For us to give the common light sequences, please provide us information which light is flashing on the printer.
For further assistance, please call Lexmark Technical Support.
The computer can not detect the printer for a number of reasons and this can be resolve by check the connection between the printer and computer. Please make sure you are using the recommended USB or Ethernet cable (network connected). Check the cable connections to the printer to make sure they are secure. For more information, see the setup documentation that came with the printer.
If connected to a network, make sure that the printer is connected to the network. Print a network setup page and check that the status shows Connected. If the status is Not Connected, check the network cables, and then try printing the network setup page again. Contact your system support person to make sure the network is functioning correctly.
