When I insert the tape, the VCR thinks a bit then ejects the tape. Just prior to this, a tape was partially eaten but did not break and the tape was able to be rewound into the case.
SOURCE: VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
SOURCE: my vcr is locked
Ok so i just posted that solution about unplugging and i remembered it was the tv/vcr button that you need to press and hold....that just unlocked mine so i KNOW it works
SOURCE: VCR tape won't eject
The flap on the door stays open until the tape is ejected. There are two possible ways to remove the tape. First, with the power off, try to locate the drive pulley or gear on the side of the tape housing. It may be possible to turn it with your finger and cause the tape to eject. The eject mechanism will move VERY slowly when you use this technique.
The second way to do it should normally be done by an experienced technician, because it involves taking it even farther apart...and it may be difficult to reassemble. There are typically four screws that hold the tape mechanism in place...two near the top front and two near the back. It should be possible to remove those screws and pull the entire mechanism out of the VCR. Then you can more easily rotate the eject pulley (or gear) and remove the tape. If this sounds a little scary, I would definitely recommend placing the top back on and acting like nothing happened!
SOURCE: SONY VCR: Keeps ejecting video tape
may be machnical stuck in playback mode. remove the cover and see the loading arms are near the video head , if not try to release the arm rotating caption wheel smmothly . don't push more force to rotate the wheel.
SOURCE: Samsung v7000 DVD/VCR .....VCR ejects tape when record is pressed
Does this happen with other tapes? If so then the micro switch could be stuck in the open position, try to give it a clean with a blast of air duster first then check the contacts on the switch. If it is happening with just this specific tape the the record tab (although in place) may be "soft" try putting a piece of tape tightly across the tab & try to record.
