I have had no issues until today. I took pictures with the camera and they saved to the card. I then put the card into my portable usb card reader and tried opening the drive and it said the card needed formatted. The photos appear on the SD card when you review in the camera. I have tried 2 different cards and 3 different computers. One of which had an internal SD reader.
SOURCE: PHOTOS CANNOT BE DISPLAYED FOR PRINTING
check the supported image size and file extension of the photo. it is possible that you got a larger orientation on the size of your photo.
let me know
SOURCE: Easyshare converted all of my jpgs to easyshare files
i'm not sure how to change the default picture program... but i can tell you that you won't lose pictures if the easyshare program is deleted. it's just an extra program to view/edit pics.... the actual pics are located in a generic folder somewhere on your computer. click properties on one of the pics in easyshare, and see where it's located. then just go to that folder through windows....
hope i helped a little, sorry i don't have the solution for the other part
SOURCE: Pictures taken can be reviewed in the camera. But,
It's a one way street...from camera to computer...not the other way around. Doing it that way will eventually corrupt the card and sometimes even the camera.
SOURCE: How do I save internal memory to a card on the
Press the Review button, then the Menu button. Use cursor-left-right to select the Review tab. Use cursor-up/down to select "Copy" and press OK.
SOURCE: kodak easyshare z740 how to copy pics from internal memory to an
Go through the menu on your camera and look for copy , it should let you copy from in to card.
have you tried connecting the camera to the PC with the USB cable instead of reading directly off of the SD card?
If i had a USB Cable, that would have been my first choice instead of going through the steps i had already taken. Sadly the USB cord was lost a long time ago. Thanks to the age of the Camera and Kodak being a developer you have to direct order which would also have taken longer. Regardless, i seem to have solved my problem myself. THe camera is functioning again. I pulled the battery and let it sit for the night. Im thinking possibly faulty card caused a static charge. Anyways the new card i got would not format in the camera this morning but once i plugged it into the computer with the internal SD reader it set it up and read without a problem. Now the camera and new SD card work fine.
This was not a solution persay. I still dont know why the camera and card decided to suddenly stop functioning as they normally due. My assessment is on the old card being bad. The camera does work now however which makes this a solved issue.
