Can't get in door
You will need Adobe Acrobat Reader to view these
documents. The Adobe Acrobat Reader is available as a free download.
I will list the Parts Manual for your Click Here=> RS22AQXKQ00_Repair_Parts.pdf
First you need to remove the plastic hinge cover's. On page 1 of the PDF you
will see the top hinges marked as location 10 and 11 Make sure power is
disconnected before removal of the freezer door and fresh food section door. Loosen
the top hinges and disconnect the wiring harness just below the top left plastic
hinge cover. Also remove the kick plate listed as location 16 and just behind
the kick plate and below the freezer door push the snap lock water connector
that joins water lines. Then carefully lift doors and place where they will not
fall or be damage water line during time doors are of refrigerator. If helpful
please rate ans should you have questions please ask, Thanks Sea Breeze
Testimonial: "Very Helpful. Bought used with no manual. Only wish we could have had instruction last night before we took off patio door. Thanks, Barb"
That You for your rate! I looked over the user manual and it did not mention door removal. I thought I had better stice with the parts manual. You can get moe Information with the4 user manual here=>http://shared.whirlpoolcorp.com/product_...
just make sure you place the model number RS22AQXKQ00 and type of request in the check box. If you have questions please feel free to ask, Thank You,John Tripp
Hi
The door control module actually consists of the door's Electronic Control Unit (ECU) and the switches or buttons integrated into one assembly. There are two of them: the driver door module or DDM (as seen on the sample diagram below) and the passenger door module or PDM, which is on the right front door. These modules are programmable.
They are also called driver door switch (DDS) and passenger door switch (PDS), so perhaps you can rephrase your search.
Please check this links to get some useful information:-
http://www.2carpros.com/articles/test-or-change-electric-power-door-locks
also check the picture attached:-
Please get back to us if you have further query or else please accept the solution.
