LG WM2075CW (TROMM Ultra Capacity)Front Loading Washer When the front door of the washer is fully, properly and securely closed - and the start button is depressed - an alarm sounds, the "Door Locked" indicator flashes and the washer won't start. The door has to be opened and closed several times - at just the right angle and with just the right amount of pressure (by pressing hard against it) - to get the indicator to recognize that the front door is closed and the washer to start. This problem is intermittent and no one ?technique? works every time. My LG is a WM2075CW. The message "PF" keeps flashing. I guess the door is the problem.
SOURCE: "Door Locked" Indicator Switch Faulty
You should access the lid switch (the switch is inside the machine main housing near the door frame) and to see whether it become loose or was broken. Good luck!
