Kenmore 24032\24036 Top Load Washer Logo
Posted on Oct 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer will fill with water but the agitator won't spin.
The washer will fill with water but won't start the cycle. I can get the agitator to move manually. The water will also drain when I put it in the spin cycle but the drum won't spin.
  • leonardw8 Oct 23, 2008
    I have a Kenmore 90 series and after my daughter slammed the lid door it does not stop filling during washing, even though the agitation works and the spin mode works. I have to put it in spin mode to empty water out of the tub.
  • Anonymous Mar 24, 2014
    fill up water but won't start agitate or even spin
Anonymous
Level 2:
Novelist:
Champion:
  • Expert 261 Answers
  • Posted on Oct 08, 2008
Anonymous
Expert
Level 2:
Novelist:
Champion:
Answers
261
Questions
0
Helped
119227
Points
471
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
  • Jorgie  the appliance guy
    No wash agitation or spin? try these:
    WATER PRESSURE SWITCH: This switch keeps your washer from overflowing. It is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has been reached. Meter check ur water pressure switch?
    You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
    If the machine starts to wash. the pressure switch is more than likely good
    ( No wash starts - then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
    Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
    Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
    Another test u can make with a multi meter is by testing the prongs individually.
    # 15,16,17 (don’t worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch.
    (where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open.
    Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
    Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
    Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
    Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
    Transmission or clutch assembly not engaging due to going out or slipping.
    Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
    Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
    Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
    CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub)
    Remember to check the agitator spline as well for worn broken teeth.
    By the way my advice is free cuz God is good!
5 Related Answers
Anonymous
  • 526 Answers
  • Posted on Jul 19, 2010
SOURCE: Washer will not spin. Does fill and agitate.
Any error code associated with fail to Spin?
Is this a FAV6800A LED console model or a FAV9800A LCD console model?
Like one of these?
Anonymous
  • Posted on Jul 23, 2011
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Anonymous
  • 242 Answers
  • Posted on Apr 14, 2009
SOURCE: Whirlpool Washer does not spin or agitate.
The motor coupling has broke , it is a small plastic rubber piece you can see under the unit that connects the motor to the gear case. very common problem about $120.00-150.00 to have repaired or $20.00 or so for you to replace. they are not simple but not to difficult to do.
Let me know if I can help or answer any other questions.
A
Anonymous
  • Posted on Jul 27, 2008
SOURCE: Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
Mike Inman
  • 219 Answers
  • Posted on May 21, 2009
SOURCE: LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
33helpful
4helpful
Why wont my washer agitate
must be worn out dogs
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Washer keeps spinning. doesn't move to next cycle
It sounds like the agitator , air bell or transmission is failing. Since the unit spins the belt & motor is ok. I recommend removing & inspecting the agitator & air bell. If they are not stripped out then you have a transmission failure.
Or, start the washer at the beginning of a cycle set to the lowest water level. After the unit fills it should be agitating stop the washer. Open the lid & try moving the agitator, if the agitator will not move it is good & no need to remove for inspection. You have a bad transmission. If the agitator moves easily then we know that the agitator or air bell is stripped out & will need to be inspected for confirmation before replacing.
Hope this helps.
Thanks for using Fixya.
1helpful
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
3helpful
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
4helpful
3answers
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
1helpful
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
1helpful
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Will only work on cycle, will not agitate in the other cycles
Thanks for your question You say it works on one cycle but not the other lets sat you start a regular wash ,the washer should fill ,wash for the minutes you have set, pump out the water #spin , Stop fills & rinse stop pump out water &spin If you try a delicate cycle and it does not do what it did on regular cycle . You have a timer problem . Thanks for your question hope i helped you solve it . THE APPLIANCE DOC
Alexander
vince
