When I the panasonic boot the DVD charger and appears on the screen HDD error
SOURCE: panasonic dmr-e55 won't work, just says "hold" on display
HOLD or X HOLD? If the latter - which is most likely - then the Child Lock has been activated! Press and hold ENTER and RETURN simultaneously until HOLD disappears!
SOURCE: PANASONIC DMR E85H
Yes you can.
You can get the instruction manual here:
http://service.us.panasonic.com/OPERMANPDF/DMRE85H.PDF
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
SOURCE: Panasonic DVD player shows EXT-L in its display.
You have switched machine onto external link mode
Either press external link on remote or find it under the flap.
Has a small child been playing with the remote?
SOURCE: Panasonic dmr ez25 no read error
Try removing the cover and clean the glass laser eye with rubbing alcohol and a cotton swab. Clean the glass laser eye.
If cleaning doesn't work, then the circuit will need to be replaced.
