Turning sharing on or off The first time you connect to a network, you'll be asked if you want to turn on sharing between PCs and connect to network devices such as printers. Your answer automatically sets the appropriate firewall and security settings for the type of network that you connected to. You can turn sharing on or off at any time. Press and hold or right-click the network you're connected to, then tap or click Turn sharing on or off. Do one of the following: Choose Yes, turn on sharing and connect to devices for home or small office networks, or when you know and trust the people and devices on the network. This setting allows your PC to connect to devices on the network, such as printers. Choose No, don't turn on sharing or connect to devices for networks in public places (such as coffee shops or airports), or when you don't knowi can not get my kodak hero 5.1 printer to work on - alertset_warning.png and devices on the network. Turning sharing on prepares your PC for sharing files and devices on a network. For more information about sharing with other people on your network, see Sharing files and folders on a network or a shared PC. The network sharing setting is only available for WiFi, Ethernet, VPN (non-domain) and dial-up (non-domain) connections. It's unavailable for domain networks. On VPN or dial-up connections, you must connect to the network first, then press and hold or right-click the network name to change the network sharing setting. Turning on sharing changes your firewall settings to allow some communication, which can be a security risk. If you know you won't need to share files or printers, the safest choice is No, don't share or connect to devices. Choosing No, don't turn on sharing or connect to devices blocks the following applications and services from working: PlayTo, file sharing, network discovery and automatic setup of network devices. Network discovery is a setting that affects whether your computer can see (find) other computers and devices on the network and whether other computers on the network can see your computer. It's one of several settings that are turned on when you turn on network sharing. You can turn network discovery on or off independently of network sharing, but we discourage this. Here's why. If you're connected to a network in a public location and you decide to turn on network discovery but leave network sharing turned off, the network discovery setting will be on for every public network you connect to from then on. This wouldn't be safe. That's why we recommend using the network sharing setting instead. However, if for some reason you need to turn network discovery on or off independently of the network sharing setting, here's how to do it:To turn sharing on or off
About network discovery
Menu used to turn sharing on or offNotes
SOURCE: Kodak ESP 3250 device driver failed to install
This down load should correct your problem. It is teh Kodak driver whiz. It will check your computer to correct any faulty drivers for Kodak devices.
http://driverwhiz.com/drivers-en?brand=Kodak&logo=Kodak&subid=1001-us-en-10000001283&gclid=CLCggv7-zJ8CFd1L5QodV0ah3g
Good Luck.
SOURCE: printer canon pixma IP1000 does not work on windows 7 64-bit
here are the windows 7 64 bt drivers
http://software.canon-europe.com/software/0035868_0010104.asp?model=
click
aomwin110ea24.exe
4070.33 Kb.
under the software label to the buttom if the page
SOURCE: Printer won't work with windows 7 64 bit
You can download Windows 7 x64 drivers here. Be sure and download both the driver and the MP Navigator (under software).
SOURCE: driver on original CD is 32-bit Intel compatible platforms only, and I use Windows XP 64-bit
goto > http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=17105
Enter the Operating system.
Download the new driver
