When turning on it immediately turns off
This issue is a common,
but hardly talked about from LG. Your tv is probably 1 or 2 months out of
warranty, and now you're hearing a series of clicks. ... If you have the
courage to open the back cover of your tv, and you do "NOT" see any
bad (bulging ) capacitors on the power supply, then it could be the voltage
regulator. After weeks of fighting
with LG to replace my tv, i decided to fix it myself. i'm proud to announce
that my 50PK540 is now working. want proof? Take a look at the video i
posted on youtube, then you will have a better understand why your tv is
clicking... I'm also selling the repair kit for this power supply board on ebay
now. LG power supply Board model number EAY60968801. With anyone of these
PCB # EAX61392501/7, EAX61392501/10, EAX61392501/11, or EAX61392501/12
with the parts if this kit, I've also fis several 50PK750 models, Some clients
have send me their broken power supply board, so I can do the repairs. Please
Make sure that you've already gone through the process of troubleshooting and
testing your tv's power supply board before making any purchases.. I recommend
that you get a tv tech to check it out, because every tv is different. Email at
[email protected] if you have any questions.and watch the video: part 1
& 2 Repair kit on Ebay http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200849231403 Youtube
video PART 1 & 2 http://www.youtube.com/watch?v=I9wF0OLyV0k http://www.youtube.com/watch?v=vHrv5XaDULI
SOURCE: LG 42pc5d plasma television.
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this will help in solving the problem.......
This issue is a
common, but hardly talked about from LG. Your tv is probably 1 or 2 months out
of warranty, and now you're hearing a series of clicks. After weeks of fighting
Take a look at the video i posted on youtube, then you will have a
better understand why your tv is clicking... I'm also selling the repair kit
for this power supply board on ebay now.
LG power supply Board model number EAY60968801. With anyone of these PCB
# EAX61392501/7, EAX61392501/10, EAX61392501/11, or EAX61392501/12 with the parts if this kit, I've also fis
several 50PK750 models, Some clients have send me their broken power supply
board, so I can do the repairs. Please Make sure that you've already gone
through the process of troubleshooting and testing your tv's power supply board
before making any purchases.. I recommend that you get a tv tech to check it
out, because every tv is different. Email at [email protected] if you have
any question.and watch the video:
http://www.viewbix.com/v/LG-Repair-KIT-now-available-on-Ebay/8ec4bea5-1d91-4d23-8180-7e5214e6c8f6
