Question about Maytag Neptune MDE5500AY Electric Dryer
MDE5500AYW Maytag Neptune not Heating
Our Electric dryer is 5 years old and it has worked great until now. Everything works except that the Heat doesn't come on to dry the clothes, so it takes way too long to dry. Any hints, I have done everything the manual says to do. Still no luck! Any help is appreciated! Thanks, Chad
    Sergeant:
  • 264 Answers
Sure I will help you when that happens that means that your heater core is no longer operating and when the heater core doesn't work when your dryer doesn't heat up anymore so that's your problem I hope I have helped you please leave a response or Stars if I have helped
Posted on Feb 07, 2018
6ya staff
SOURCE:
Anonymous
SOURCE: Maytag neptune dryer won't start
Hey all neptune stricken owners - I removed the circuit board which was darkened substantially in the resistor area, but the maytag repairman got no money this time!! . . . And the cold is no longer the problem it has been for the past couple of years. We replaced the 3 main capacitors(blue) and the cluster of four resistors(brown) - and voila - the dryer works like new!!! It only cost a few bucks ($.67, $.92 etc etc) as opposed to the $151 a new board was going to cost!
Posted on Jan 20, 2008
Anonymous
  • 1028 Answers
SOURCE: Maytag Neptune MDG9700AWW gas dryer. Problems
be sure vent is clear all the way to outside try a load with vent disconnected ..also if gas dryer may be a problem with burner reigniting after heat up if so try replaceing both coils on burner valve
Posted on Jun 06, 2008
SOURCE: maytag neptune dryer MD6
All you need to do is check the element for continuity with an ohm meter, if it has continuity the element is good. The dryer also will run on 110 volts of power but it needs 220 volts too run the element, so check and make sure all the conections on your cord are secure and that you have 220 at your wall outlet.
Posted on Jun 12, 2008
doug320
SOURCE: Maytag Neptune - everything works, not getting hot
My 2 yr old Maytag Neptune gas dryer mod # MDG9700AWW does not get hot. The gas is
on but the dryer does not light? Is their anything I should check before I call
for service? And if I must call for service who is reputable in the souther california area?
It's ironic that when I purchased the set I added insurance on the washer only thinking the
dryer would be pretty fail safe! HA..... This is the third time the dryer has failed on me yet
the washer is doing fine. Dont figure!!!!!!!!!!!!
Anyhow Thanks for any help you can render?
Posted on Dec 04, 2008
James Chandler
  • 686 Answers
SOURCE: Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Posted on Feb 23, 2009
Dryer running fine but just stopped heating. lint traps all clean.Maytag Neptune MDE5500AYW. HAVE THE DOOR AND FRONT PANEL OFF ALL ELEMENTS LOOK CLEAN AND ATTATCHED. No problem with home power...
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 23, 2011 | Maytag MDE5500AYW Electric Dryer
Not getting any heat on any setting. My Neptune dryer is now 6 years old. Is it possible a fuse has blown? Thank you.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 06, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Our dryer works but does not heat up. this is onl...
heatman101
May 20, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The lights on the dryer work it wont start it didnt have any problems drying before this happened no odors or smells i have a maytag MDE5500AYW. please help. thank u
If the display on the dryer reads '88' then place a heating pad over the display. After a few minutes, the '88' code will clear, and it will work fine. Sounds crazy, but works every time for me.
Sep 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a MAYTAG MDE5500AYW drier that spins but doesn't heat up. Any recomendations?
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Watt for dryer
Total 5500 watts for motor timer and heating element on an electric model. (estimated)
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My maytag will not run
My neptune dryer electric mde5500ayw will not start the button seemed too be struck, and how can i take the side panel off to check the fuses inside
Nov 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer MD6
Jun 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
428 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
