Need Manual for Slot1 PIII Gateway Jabil Tabor III Motherboard.
The memory specifications for that motherboard are as follows:
100-megahertz (MHz) Memory Bus Speed (FSB)
Three 64-bit or 72-bit Error Checking and Correction (ECC) 4-clock, 3.3V, unbuffered synchronous DRAM (SDRAM) Single or double-sided DIMMs in the following sizes: 8 MB, 16 MB, 32 MB, 64 MB, 128 MB
Expandable to 384 megabytes (MB) of SDRAM, CAS latency of 2, using 64-Mbit chips
DIMMs must adhere to the Intel 4-clock 100-MHz 64-bit unbuffered SDRAM DIMM specification, latest revision
Uses gold-plated DIMM socket
ECC signal and multiple bit detection, single bit correction, supported, using ECC DIMMs, can be enabled and disable in the BIOS Setup Utility
how much ram does my MB support? E139761 and what type?
