Televison & Video Logo
Posted on May 13, 2017
Sony Bravia Model No.KLV-32BX300 LCD TV is with me but i cannot take the audio out from the TV. I undertand that there's an audio output which I don't understand. This may sound a bit stupid t
How do i remove demo loop off sony Batavia 32bx300
Sir
pleas press menu +setup+factory setup and set turn restart and then select every thing again please take care when set asked home mode or shop mode select home mode at that time
My sony bravia lcd tv good with backlight and sound,but no pictures on it... SONY, Model no:KLV-32BX300. Serial no:2349014. pls i need an help sir...
try a search for the video driver it's the part that is most likely gone bad. if you look at the board or that part it might have a bad capacitor and could set you back a few bucks.
1helpful
I have a Sony bravia KLV 32bx300 LCD tv. From like 2 months the tv isn't turning on , it tries to turn on for 3 times with green light on and it stops starting and tv goes to 6 red LED blinks, when th
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Colored line in sony klv-32Bx300
It would probably cost more to fix than it would to buy a new one.
I have sony LCD Tv klv-32bx300.when turn on the tv sutenly power getting standby.what is the resan?
I have a tv sony lcd klv32bx300 when turning on works for about 15mins then sfhuting down and blinks 3times the red led on standby signal . Then stop for 2sec and again blinks 3times. I bought this tv in the middle east but we are h ere now in phils. I br ought this problem here in sony service center but the cost to repair this problem is half of the price when i bought. Any one can help to fix this problem
12helpful
2answers
8 blinks from a sony bravia model klv-32s400a tv
8 blinks in KLV-32S400A shows Audio Error
Check audio voltage supply from power supply board, if OK, replace GP Board (main board)
and if audio volts are not available, check/ replace power supply board.
4helpful
3answers
Problem using headphones 3.5mm output with Sony Bravia tv
Just mute the TV and you will get sound out of your headphones. You may have to turn the TV sound up though.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
