Question about Symbol PPT2846 Portable Terminal
Symbol Pocket PC ppt2846 software install
I have a Symbol Pocket PC ppt2846 with a cradle and a serial cable. I'm tryning to connect to a laptop so I can move some software to it and install it. I'm having trying connecting to it, and I'm not sure how to install software on it once I am connected. I'm not seeing much help in the form of product manuals or support from the symbol website or forums. Can someone direct me to some information that can help me?
  • 661 Answers
See chapter 12 of the reference guide
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5093102apdf&sliceId=&dialogID=76630451&stateId=1%200%2076626512
use TCM to configure the software you require to upload (and where it goes)
then use the hex loader to upload to the terminal.
Posted on Oct 10, 2008
6ya staff
SOURCE:
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
How to connect pc to motorola pda mc 9090
I'm not sure exactly what you mean by this question. You might want to give a little more detail. Do you have a single slot cradle? You'll want to get one if you don't have one. Then you connect the cradle to the PC using a standard USB cable.
To be able to browse the files on the PDA from the PC, and copy files to it, install software on it through the USB connection, etc, you will want to download and install ActiveSync on your PC. Just google ActiveSync and you will find it on Microsoft's web site. It is a free download.
Thanks,
Brad Radaker
Radicomm, Inc. (makers of QuickTalk, push-to-talk over WLAN software for the MC9090)
www.radicomm.com
Apr 14, 2009 | Symbol MC9090-G RFID Handheld Barcode...
Can I upgrade a Symbol PDT8100 from Pocket PC 3.0 to Pocket PC 2003 or maybe MC50? I would like to do it myself. Thx.
PDT8100 can be upgreded to pocket pc 2003, however you will need to purchase a license to do this. Once you have the license, you will get the required files to update it.
You will need a cradle , cable and power supply to do this.
Feb 26, 2009 | Symbol MC50 Pocket PC
Symbol Pocket PC 2003 ( MC50) wireless connection errror
Just upgrade the software on it to version 21 from Motorola site
Dec 02, 2008 | Symbol MC50 Pocket PC
Help active sync will stay in limbo attempting to connect to cradled axim
Does your system detect the handheld? After you connect the cradle or cable to the computer, then you should be prompted to install drivers for the handheld. Make sure that Dell Pocket PC appears in the Device Manager.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Dell Axim doesn’t support serial connections?
There is another thread on this board where a number of people talked about serial connections and alternatives. I also want to connect my existing AirMap 100 GPS via serial cable. The Dell moderator (Rollie) pretty much put an end to that thread by stating: "A serial cable is not available @ this time and when one will be available is unknown"
E-125 and Cradle/Internet access......
I don't know about the craddle - but I guess it should work too. I use a USB cable - and it works okay. You need to run MS ActiveSync (install v. 3.5 - it's better), and when you see a green circle in your taskbar, you can try and access Internet (your desktop should, of course, be connected to Internet).
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
Symbol PPT2846 Portable Terminal Logo
456 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
