Sh interface slot:1/mod:1
INTERFACE slot:1/mod:1 SETTINGS
Description: GWC Modem Driver
Type: RS232
Speed: 0
High Speed: 0
Administrative Status: Up
Operational Status: Down
Link Up/Down Traps: DISABLED
Promiscuous Mode: FALSE
Connector Present: TRUE
Filter Access: ON
Last Change: 0d 00:01:06
Input Filter:
Output Filter:
Host Type: SELECT
Connection Type: NORMAL
Port Type: LOGIN_NETWORK
User Name:
Access: TWO_WAY
Dial Prefix:
Init Script: USR_int
TCP Port: 0
Protocol: PPP
Prompt: \nlogin:
Prompt Style: LOCAL
Message: \nWelcome to 3Com Total Control HiPer ARC (TM)\nNetworks That Go The Distance (TM)\n
Host Address: 0.0.0.0
Disable Authentication for call type: NONE
Login Service: TELNET
SOURCE: I can not get two print servers to work on my network
I would suggest that you set a higher Ip address then 9-10 as it is possible that your router/switch is possibly using one of these for DHCP, I have one of these myself, I had to put mine a little uprange to prevent my router / switch from interfering with it.
SOURCE: cisco asa5505 problem
You seem to have the last resort (o.o.o.o) set to VLAN1 which is set as an inside interface.
Is VLAN1 connected to the outside router or internet backbone?
If not, change the last resort to the outside Ethernet port.
SOURCE: Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
SOURCE: i need a driver for my sound card
Hi!
You can download you drivers here:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/netvista_drivers/dsiz31us.exe
Or
Go to supoort.lenovo.com using Internet Explorer and use Run AutoDetect.
Thanks
