You can get it working sometimes if u mess about with the trigger
It sounds like you have a problem with the switch or battery. Try cleaning the battery contacts first and then remove the battery and look into the tool and see if the switch contacts are bent not allowing battery to seat firmly. If that is OK then I would think that you need a new switch. MAKE note of how you remove it because it is polarity sensitive. Let me know if you need more assistance.
SOURCE: Cannot engage hammer action
the problem is the metal part of the clutch that meets the pin from the transmission. remove the 4 screw from the clutch & check if the the inside of the clutch & the trans pin meets. all you can do is to push back the metal parts of the clutch setting.
SOURCE: The motor turns but the clutch will not engage
Take the drill out of the hammer drill setting when in reverse. Using the drill setting with the speed on 1 will give the power to free the bit. If the clutch will not engage, GENTLY but firmly switch between forward and reverse. This should work just fine. I hope this solution brings you success! Best Regards, Michael Mittelsdorf
SOURCE: i have an 18v dewalt hammer drill dc925 and cant
It's one of the settings on the clutch ring. Or do you mean it won't turn there?
