SOURCE: Mechanical error - print cartridge cradle can't move
4 years is quite some time for a printer especially if it is a home printer. Manufactures practically make there printers to **** down. You should be glad it lasted this long. If it carries a memory module then it might of gone out. Printer hold print jobs in there memory so if it gets full, the will stop working.
SOURCE: SHARP AL-1641CS
There is a small clear carriage lock on the underside of where the finish page somes out. If it gets hit slightly it will lock up the carriage and make that horrible sound.
SOURCE: dlink WBR 1310 error 109 internal error
Remove the CD setup. Try calling your Dlink Manufacturer to help you install the WBR-1310 manaully.
does this occur after while, during or after printing?
from what application are you printing?
sounds like the print you are sending may be too big for the memory of the printer, or it can not recognize the file type.
