Give me the solution of CLX -3186 Color Printer so the error cme on printer Display that To replace the New Image Kit. find me the answer to Reset the cming code .
SOURCE: My Dell 962 Photo Printer gives error when trying to photocopy.
The issue you are experiencing with your printer i.e error 2200 is related to "Scan Carrier Stall error" I believe the steps mentioned below will fix the issue,
1. Unplug the power cord from the wall socket.
2. Disconnect the power supply from the back of the printer.
3. Wait 15 seconds.
4. Reconnect the power supply to the back of the printer.
5. Plug the power cord back into the wall socket.
I would appreciate if you could let me know if you have refilled the black cartridge, cause Dell printer often give error messages if the cartridges are refilled and not replaced with an original Dell one. If you have done so please replace the cartridge with a genuine Dell cartridge.
Regards
Malik Khan
SOURCE: Hp 6310 printer gives error reading
Thanks for your e mail Fixya.com suggesting I join your premier plan at a cost to me where you would be happy to solve the problem at a cost. and asking me to let you know how I fixed it if I managed to fix it myself
Obviously one does not get anything for nothing and, as I'd need to pay for your plan to get the solution I guess with that same outlook you'd need to pay for my knowledge to know how I fixed it
c'est la vie
SOURCE: Canon Image runner C 3200 printer gives error code E000677-0080
your quickbooks file is in the wrong format example tiff or pdf let your it know they can change it to the correct file format
SOURCE: Samsung clx-3160fn change image unit
Kindly take out the imaging unit out of the printer and take out and put it properly.
If this did not fix you may try using the imaging unit from other printer.
If this did not solve then visit a service center or buy its Imaging unit.
SOURCE: Canon IR 3100 error code (E000020-0081)
error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
Please dont forget to vote this answer was helpful.
Many thanks
