I love this washer- but recently, the loads seem to make the agitator 'slip'- as if there are broken teeth on a cog- it does not agitate like it used to. I have tried doing lighter loads, filling all the way and adding balanced weight loads, no load, hot, cold, etc, but nothing makes a difference. I cannot afford a new washer, and I am very careful not to overload, although I am not the original owner (washer came with house) I only do the usual- sheets, towels, clothes...no heavy duty or highly soiled items, and I use good detergent, only add bleach to a full washer, then the clothes, (The bleach dispenser has never worked) and use no in-washer fabric softener, so nothing goes IN the agitator column. There is no corrosion in the wash basket, or chips. I clean all parts regularly- hinges, underneath, lid crevices, and have a heavy duty in and out line on the washer. Please help. I am pretty handy, and if I can fix this, I need to. Thanks!
This is for the whirlpool washer,if you grab the top of the agitator can you spin it both ways without it grabbing,it should only spin one way,if you can spin it both ways you have bad dogs,the agitator cam kit part number is 285809 and it's around 13 dollars.pop off the center cap of the agitator,remove the 7 1/6 inch screw in the middle and pull off the top of the agitator to get at the dogs,you'll see them there are 4 of them,they waer down and the top of the agitator doesn't work.watch this video.
http://www.youtube.com/watch?v=ensJz0h6wLM
SOURCE: Bleach/softener dispenser
Don't only clean the strainers at the ends of the hoses, there are pull-out strainers that are in the male hose connectors ON THE MACHINE. pull them out and clean those as well. Soaking in vinegar will help.
SOURCE: bleach and softener dispensers filled with water at end of cycle
I have a 4-6 month old Bosch with same problem (being new unit I am positive there is no buildup in drain). Have called Bosch, not much help. Called repairman (under warranty), replaced a water inlet valve, didn't help. I noticed that if you add water to the dispenser cell that is partially full it will begin to empty (syphon effect),, but will never totally empty (can't due to the design). So, the problem must be that the water that is designed to flow into the dispenser cells during wash cycle for the purpose of flushing, is not always getting there. Can it be fixed? Call Bosch.
SOURCE: Bleach and Softener dispensers do not work.
you have to remove the compartments and clean them out,, could have lint build up blocking it
SOURCE: The fabric softener and bleach tray won't drain
clean the caps sometimes they get clogged and cannot syphone
SOURCE: Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
