Dear Its related to fusser temp. Check the fusser assy. thermostat it may open . either it may reset or replaced with new one. The error code mean-OPEN HEAT ERROR.
thanks
The Samsung printer error code u1-2320 is related to fuser that means the fuser unit fails. Need not to worry; this error can be encountered by many Samsung printer users. ... The Samsung printer error code u1-2320 is also the fuser error; this might be resolved just simply power off the printer.3
Below are the command sequences that can be applied to default the parameters referenced above:
Examples:
! U1 do "device.restore_defaults" "bluetooth"
! U1 do "device.restore_defaults" "ip"
! U1 do "device.restore_defaults" "wlan"
! U1 do "device.restore_defaults" "power"
! U1 do "device.restore_defaults" "display"
The zpl parameters can be restored to their factory defaults on the P4T series, RW series and QLPlus series by deleting the ZPL_CFG.CFG file. This binary file contains the zpl settings and will be recreated automatically when restarting the printer. The newly created file will contain the binary equivelant of the factory zpl default settings.
The ZQ500, QLn series and the iMZ allows the ^JUF and ^JUN command to be sent to restore parameters to their factory default condition.
Example: ^XA^JUF^XZ^XA^JUN^XZ^XA^JUS^XZ
Please note that the iMZ uses line print mode by default. The command ! U1 setvar "device.languages" command may need to be adjusted to se the iMZ back to ZPL if necessary.
! U1 setvar "device.languages" "zpl" Zebra Technologies Restoring Factory default settings with Mobile PrintersCCTV Networking Technical Support
