Download the manual from the link below.
service.us.panasonic.com/OPERMANPDF/DMCTZ2.pdf
Hope this helps.Thanks!
SOURCE: Video playback problem on lumix dmc tz3
First Bob, I believe there is a menu setting that allows you to disable picture/movie deletes as long as it is enabled. Check this out regarding "this picture cannot be deleted" problem.
Second, assuming your screen is ok since you can read a message from it, I would try FORMATing your memory card, after downloading your pics/movs to your computer from the camera. Note to view MOVies from your camera on your computer, Windows Media Player will not play them. You must download Apple's QuickTime Movie Viewer to view .mov file format from panasonic cameras, or use a view that came with the camera on CD.
SOURCE: panasonic DMC TZ3
Just go & download the free Google Picasa 3 program. It is a good viewer & downloads images from a wide range of camers.
SOURCE: How do you unlock the memory card on the Panasonic
Make sure the write protect lock is off by taking the card out
of the camera, face the card towards you, look for a small white tab on
the left hand side of the card, to unlock it push the tab down, it will
be at the side of the card like this .
Hope this helps.
Good luck
SOURCE: how do you delete multiple pictures from the
The quickest way to multiple delete pictures from you camera after you have copied or backed them up is to use the camera's menu to format the camera or/and card.
Regards.
SOURCE: Can the Panasonic Lumix DMC-TZ3 camera be used as
Well-not easily. It will not work through USB. An out-of-the-box camera only lets you access camera memory card/onboard memory. However you could connect the camera video-out socket to a PC with graphics card with video capture function. Some cards with video capture work with skype (check this URL:
http://forum.skype.com/index.php?showtopic=41101 )
At the moment this seems to be the only easy way to use TZ3 as webcam.
Good luck,
Raf
