Question about Disgo 6000 Tablet
DISTAB6000R battery charge
Will not charge and will only work when plugged in
    Champion:
  • 274 Answers
It maybe not a good battery. while it plugged in for charging, it will reduce the battery life. Or suggest you contact the supplier and check what's up.
Android 4.0 Tablet PC
Posted on Feb 09, 2012
6ya staff
SOURCE:
My Kindle Fire hdx 8.9 turn on. I pressed button for 40 seconds but it did not work.
Most Kindles only take a brief touch of the on/off button Have you tried charging it? Try plugging it in for a few minutes and then try to turn on. If it works while plugged in then leave it to fully charge. If it fails to hold the charge then take it with you to a place like Best Buy or Batteries Plus. That's the quickest way to get anew battery and be sure it's the right one. I'm sure either one of those could test the old battery before you buy a new one. You could also order one from Amazon.
I've had my Paperwhite for about 6 years, charged at least once a month and still haven't changed the battery.
May 31, 2016 | Amazon Kindle Fire HD 8.9"
What does the lightning bolt inside the battery symbol mean on the screen of the digiland tablet dl700. It wont charge
That symbol means that the tablet battery is plugged in and is supposed to be receiving charging voltage. If the battery is bad, it may not charge but the tablet will still work with the charger plugged in.
Feb 04, 2015 | Tablets & eReaders
How do i tell if my zeki tablet has a dead battery
I think you answered your own question. If you get a charging indication when plugged in and it stays on only while plugged in, that mean the internal power supply is accepting the charger power and trying to charge the battery but your battery is toast and will need to be replaced. The same principle would apply for any laptop or smartphone for that matter.
Dec 05, 2014 | Tablets & eReaders
Tabeo tablet battery not charging will work if plugged in
Hi! Hope this may serve as a hint. When power problem dooms to any electronic device needing battery operation we sometimes least assume that the battery life is near to its end. I mean its charging life has come to end. However, you can sometimes recycle it's life cycle by discharging fully and recharging fully without using it. Battery utility softwares can help monitor its life but cannot revive at all. Charging also using fast charger and or slow charger can help reactivate the battery cells. I personally experience, a gadget of mine its charging life is almost come to end and when I accidentally plug it on my laptop with 3.0 USB offline charging capability it somehow raise its life but not as good as it is. If the above doesn't work at all, it's time to change the battery pack. Goodluck!
Mar 09, 2014 | Toys R Us Tabeo
Tablet wont charge
Hi It will not charge. Are you sure that the battery is OK? Do you charge the tablet with electricity or via USB? You have checked the cord and wire into the the plug and the plug itself. Is it possible for you to borrow a charger to find out if it is the battery that is not working. All the best Kolbrun
Sep 18, 2013 | Toys R Us Tabeo
My Samsung Galaxy Note 10.1 battery not charging can you please tell me why
Same problem on my Samsung Galaxy Note 10.1 (GT-N8013) w/ OS 4.1.2
It just boots up and shuts down.
Dec 06, 2012 | Samsung Metallic Gray Galaxy Note 10.1in...
Fujitsu siemens stylistic M532 tablet not charging battery
I have just had same problem. Battery on M532 absolutely refused to charge from flat.Tablet worked when plugged in so I downloaded an app killer from android market and killed all but the essential apps then tried again and it seemed top work! Maybe background apps draining battery at faster rate than could be charged?
Nov 08, 2012 | Tablets & eReaders
Put a new battery on still does not work
Note: do not plug your laptop if not using this. this will damage to your battery this the most common cause of battery problem due to over charged without unplugged. pls remove after charge. this can also damage to your main board from power supply section. thanks romsky79@yahoo.com
Jun 06, 2009 | Gateway M275 Tablet PC
Battery is not charging
Let the battery go all the way dead. You may have to adjust the settings in your bios so that the laptop will stay on until the battery goes completely dead. Then charge the battery. Do this a few times if it does not fix the problem you do need a new battery.
Jan 21, 2008 | Compaq tc4200 Tablet PC
Disgo 6000 Tablet Logo
282 people viewed this question
Top Disgo Tablets & eReaders Experts
Marvin
Marvin
Are you a Disgo Tablet and eReader Expert? Answer questions, earn points and help others
