Sony Cyber-Shot DSC-P32 Digital Camera Logo
Posted on Oct 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lens won't in on camera and makes clicking sound.
I dropped my camera on the floor which wasn't a far fall and it was on the carpet and now the lens won't go in, and it makes a clicking sound. and when i turn it on it says turn on and off again.
  • jtplus5 Oct 30, 2008
    It was at a friend's house and looks like it has been dropped. the lens is stuck in the extended position and slightly off-center with what appears to be a few dirt particles between the lens and camera body. when I turn the camera on the screen says to turn power off and on again. when i do that i hear a clicking noise(probably trying to retract) then it stops but the lens remains extended. no luck with trying to gently move the lense back to center.
Anonymous
Level 2:
Novelist:
  • Expert 107 Answers
  • Posted on Jun 09, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
107
Questions
0
Helped
34727
Points
325
When you dropped your camera, some dirt got on the outside of the lense or some mechanical part of the lense broke or dislocated. If some of the mechnical part of the lense is damaged, you need to open up the lense from the camera and inspect the parts. Look for loose parts, then clean it and put it back.
I had the same problem with my sony Cyber-shop, but it was not dropped. somehow one or more small piece of dirt got on the outside of the lense. Here is what I did and the problem was fixed for good.
While turning the camera off, I pressed on the lense (up and down motion) softly. After a few times, the lense retracted 95% of the normal retracted position. I then, pressed the lense a little harder in untill it was fully retracted. It has been working okay since then.
You should always keep the outside of the lense clean and do not drop it.
Good luck
Camera lens cover won't open when you turn the camera on. Says "power off then on" but still stuck
This kind of problem occurs if camera dropped on floor that broke lens mechanism OR lens mechanism got dust particles that make it stuck.
Usually lens mechanism needs to be replaced to solve the issue, however, user level try to solve the problem is to tap camera on your palm a few time gently that may release stuck lens mechanism and it start working again, if that does not help then lens assembly will be replaced.
Thanks.
My sony digcam lens is stuck.. it just make some annoying sound but it doesn't close completely or open at all. it just say off and open ur cam.. how can i fix this? it fell 4 feet high.. but it...
Hi.
The drop has cause internal damage to the moving parts of the camera. The shock of the camera hitting the floor will have caused this.
The cost of the repair will differ depending on the damage caused by the drop.
You can get a quote directly from Sony by clicking on the link below or you can take the camera to a certified repair store.
https://eservice.sony.com/webrma/web/index.do
Regards.
Jun 02, 2011 • Cameras
Hi, someone drop my Ricoh R7 camera in the floor and since then the lens can not be withdrawn. It make some noise but isn't moving and doesn't switch on.
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
My Olympus vg120 switches on but the lens won't pop out. It makes a noise and tried to open but doesn't
Sounds like it has been dropped and is off track/set .As long as it wasn't broke electronic tech could fix it. Dont spend much tho cause they are around 75 bucks online now.
May 08, 2011 • Cameras
2helpful
Zoom lens will not open - camera will not open
Drop the camera onto a carpeted floor from about a foot and a half to two feet. I did this once when my DSC-H50 had the same problem and it immediatly began to work again. It landed just on the fron edge of the cylinder around the edge. I left the lens cap on. Many people have had this same problem with other sony models and it works well for them as well. I know it sounds far fetched which is why I am including this link: http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscp200_question.html?qid=3653
That is where i found the information to fix the same problem you are experiencing.
Fujifilm digital camera finepix a 500
Check ou this link: http:// www.digitalcamera-hq.com/digital-cameras/fuji-finepix-z1_question.html?qid=4289
After the basics (cleaning the lens, replacing the batteries, etc.), try dropping the camera on a carpeted area from about 2-3 feet. It worked for my Fuji A500 and 90% of the responders on the link. Everything on the web said it would cost ~$100 to fix. I was in the process of researching new cameras to buy and had nothing to lose by dropping it on the floor.
The error may be caused by debris in the zoom mechanism preventing it from working. Dropping the camera loosens the debris and voila!
HELP! Zoom Error?
Common fix is to remove batteries hold the power on button down for five seconds and then try it.
I take it the lens isnt off true / loks straight?
A Dropped Camara. Please Read
That is what casio calls a lens error. You will have to send it in and have it fixed. The cameras don't do well even when dropped from that short distance. Call repairs at 800-706-2534 and keep choosing option 1. Tell them that you talked to tech support already otherwise they will try and transfer you to their tech support.
My Canon Powershot SD400 won't turn on and lense won't go back in
Unfortunately the lens assemblies in these compact digital cameras are quite delicate. The drop probably knocked the barrels of the lens out of alignment preventing it from moving. You can try to GENTLY twist the lens back and forth, you may be able to click it back into alignment allowing it to function normally. If the gentle manipulation fails to fix the problem you will need to get the camera serviced by a professional. There are quality repair services on the web who will work on your camera. David Millier Advance Camera Repair
9helpful
4answers
Focus error
Check out this link: www.digitalcamera-hq.com/digital-cameras/fuji-finepix-z1_question.html?qid=4289
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
