In maintenance mode Menu* 2864 how do I clean magenta printhead seems to be blocked.
SOURCE: unable to clean
I have the same probolem as obove but will not work on ;my printer. Where is the wasitank?
SOURCE: Brother MFC5840 CN Print heads
Stuts,
I guess you have used generic ink carts.
You should buy an original brother ink cart.
When done so make sure all other carts are at full level:
Press menu then start b/k copy then fourtimes arrow up (tel.index). Machine will be in maintenance mode. press 7 then 6 then 4 then start b/k copy. Machine will refresh ink within tubes and print head and do some power cleaning. when finished press 7 then 6 then 3 then start bk copy to run an extra power purge.
Leave maintenance by pressing 9 then 9.
Do run a quality test print.
If you re lucky the ph will work again.
THERE IS NO WAY TO CLEAN THE PH OUTSIDE EXCEPT BY Power Purge (7-6-3) within maintnenace mode.
If you like to save money refill ORIGINAL Carts by drilling a 2mm hole into the top (O of brother brandname) . You can leave the hole open to refill the cart next time directly without taking it out of the printer.
Mix some 3ml 85%-glycerin alc (drugstore) with 3ml of destilled water and 5 ml of DYE(!) ink and refill the c/y/m cart.
For bk mix 1 ml glycerin alc with 4ml dest. water and 15 ml bk DYE ink (shake well before refill).
This is -nearly- the exacte mixture of original brother ink.
SOURCE: mfc 665-cw magenta clogged?
Do you use some very cheap generik ink?
If your ink wont match the specifications of the needed one clogging is the result.
If you have tried several cleaning there is unfurtunately nothing more what you can do: the ph is dead (for mag).
SOURCE: Brother DCP-130C refuses to print the magenta ink
If you don't print at least once a month, you will clog the machine. You unfortunately have to get it fixed by a professional or get a new printer. Sorry!
Hi, I tried the solution above "by obiewan" it work's for me but I do a little changes on his pattern.
1. Unplug your printer
2. press down the menu/set then plug it (just keep oh pressing it down until you see the message error 46 show up on LCD)
3. press 80
4. then look for "Purge", i think its on the 25th when you scroll down
5. then reset the pruge count to "0" by pressing 2 7 8 3
6. then press stop/exit
7. then press 9 twice
VOILA!!!
