Question about Miele Novotronic T230C Electric Dryer
Miele T230c service manual - Miele Novotronic T230C Electric Dryer
    New Friend:
  • 40 Answers
This is a link to the user manual. There are no service manuals for consumers.http://www.miele.co.uk/Resources/OperatingInstructions/T%20230%20C.pdf
Posted on Feb 09, 2012
Anonymous
SOURCE:
ginko
Ginko
  • 19396 Answers
SOURCE: ho perso manuale di uso e manutenzione posso averlo on line ?
Clicca il link qui sotto per scaricare il manuale in Italiano:
Download italiano Libretto d'uso
Qui c'e anche la pagina di supporto Miele.
Non dimenticarti di votare adeguatamante la mia risposta, se questo ha risolto il problema vota blu, se ha aiutato blu, se non e' di aiuto giallo, il rosso e' per chi ti insulta.
Io direi che se cercavi il manuale qui il blu ci sta'.
Ciao, e in bocca al lupo con l'asciugatrice.
Posted on Feb 27, 2009
Linda74
  • 70 Answers
SOURCE: Miele T230C do no start
If start LED does not blink, most likely fault is your door lock.
Posted on Mar 28, 2010
danny Hendrickson
  • 2468 Answers
SOURCE: Miele Novotronic T230C Electric Dryer Dryer is
first check for 240 volts input on the unit if its electrically heated if you have no heat at all,then if you have some heat but it cycles on and off heat wise and the heat isn't as high as it should be,it can be the high-limit thermostat,the cycling thermostat both on the element housing,or it can also be a thermistor sensor on the blower housing if it only acts up on certain settings,you can bypass the 2 components on the element by jumping the wires on the components carefully together temporarily to see if this helps the heating cycle,but not the thermistor,as this is a resistance sensor
Posted on Oct 05, 2010
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: miele novotronic t230c condesner dryer rotates,
Probably a clogged condenser. With the condenser full of lint the dryers ability to work right is greatly diminished. Remove and clean the condenser.
These are relatively new in my area. I have posted Miele service manuals for washer and dryer HERE.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 03, 2010
BarrettDenCo
Barrett Palumbo
  • 1772 Answers
SOURCE: my miele novotronic t230c is
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Posted on Dec 21, 2010
Where can we get circuit drawings for the T230C?
not sure if this is what you are looking for but go to this link and have a look might help you out.... circuit drawings for the T230C Google Search
Oct 24, 2017 | Miele Dryers
Miele T230C dryer keeps tripping out after only a few seconds?
Mostly likely cause is the heater element part no. 6138580. To ensure this does not happened again 1. Ensure appliance is situated in a cool room with ventilation (If room to hot it will not condense)
2. Ensure metal heat exchanger at bottom of appliance is rinsed regularly both long way and width ways.
Feb 01, 2011 | Miele Novotronic T230C Electric Dryer
My miele novotronic t230c is not generating heat but work fine in all other areas. can you advise me please
Dec 21, 2010 | Miele Novotronic T230C Electric Dryer
Miele T230C no water being extracted at all... no heat ...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 18, 2010 | Miele Novotronic T230C Electric Dryer
Jan 04, 2010 | Miele Novotronic T230C Electric Dryer
It trips out the electrics
If your circuit breaker is warm when it trips. Then you need to replace the breaker. Need to know how to use a meter also.
Aug 11, 2009 | Miele Novotronic T230C Electric Dryer
No heat out Miele T234C dryer.
Most likely fault is filters have been clogged and tripped the safety stat on rear of appliance. Wash filters and replace stat Part No. 5432530
Jun 26, 2009 | Miele Novotronic T230C Electric Dryer
Ho perso manuale di uso e manutenzione posso averlo on line ?
Jan 05, 2009 | Miele Novotronic T230C Electric Dryer
Open Questions:
See all Miele Novotronic T230C Electric Dryer Questions
Miele Novotronic T230C Electric Dryer Logo
1,833 people viewed this question
Top Miele Dryers Experts
Mike
peter gittos
peter gittos
Dw Wooten
Dw Wooten
Are you a Miele Dryer Expert? Answer questions, earn points and help others
