SOURCE: Remote Codes for new Sony Bravia
Sony has unique code for all equipments, those are 0000, and 0111, if doesn't work with your tv the problem it is on the remote control.
SOURCE: sony bravia won''t play PS3
Try setting the resolution to a higher grade or a lower grade.. That solved the problem for me.. good luck!
SOURCE: Sony KDL40S2010 Bravia LCD TV... turns off / on on it's own
If TV does not remain in standby and turns on itself then power switch on top of it could be defective and power supply board is also suspected. Take off its back cover and unplug top switch connector just to confirm is that cause of On-Off its own. If problem still exist then power supply board has problem and will be replaced. Let me know the results to move forward.
SOURCE: Sony KDL46XBR switches itself off randomly light blinks red twice
Your power board got zapped you will need to replace it.
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
