Hello. I just Installed a fresh Windows 7 on my Asus G73jh notebook. Even Before installing the Graphic card driver, during the installation of a random file i got a Blue screen mentioning that "its is the 1st time you are seeing this" and below the screen there was a process of PHYSICAL MEMORY DUMP going on. Well this is the specific problem. BUT I am facing this problem for a while now ...ITS ALL RANDOM!! all of a sudden...I have installed windows and every thing perfectly in the past but this Blue screen pops up al of a sudden without any clue of ow this is happening. Last time I installed my windows was because of the same Blue screen which didnt let the windows to start AT ALL. It was only operable in SAFE MODE. Here are the details of the problem which i got by Windows "check for solutions" page in the "show details" section. NOTE: This is the time of my latest Windows installation. Problem Signature: Problem event name: BlueScreen Additional Information about the problem BCC Code: d1 BCP1: 0000000000000010 BCP2: 0000000000000002 BCP3: 0000000000000000 BCP4: FFFFF88015075D6 OS Version: 6_1_7600 Service Pack: 0_0 Files that help describe the Problem: C:\Windows\Minidump\011212-14788-01.dmp C:\Users\Ali\AppData\Local\Temp\WER-31028-0.sysdata.xml Please help as it has given a lot of serious problems and put me in crucial moments.
You can check at microsoft at this link https://answers.microsoft.com/en-us/windows/forum/all/blue-screen-error-bccode-d1-windows-7-64-bit-pro/d488fd83-09d2-49d3-93fa-7352a39c2fad
for the answer to your problem
SOURCE: can not install sound card on Asus F5R
alrighty, check your bois see if your audio device is disabled, also check in device manager if theres any multimeda devices that have no drivers, then go to sounds and audio devices in controll panel and select the device and theme for your pc some times Windows has a dedede moments hope this helped ^-^
SOURCE: BCCode: 77 BCP1: 00000001
BCCODE Error is caused in one way or another by misconfigured system files.
try this http://www.eusing.com/free_registry_cleaner/registry_cleaner.htm
will clean and repair the registry read instruction first and disclaimers etc.. if no joy then try system restore and at the worst a reformatt and reinstall of windows
SOURCE: My Laptop specifications are, ASUS
Seems like your Bluetooth and Wifi settings are disabled from BIOS.
On laptops usually there is a setting in BIOS where you can disable/Enable Wifi+Bluetooth.
Shutdown computer
Turn on computer and press "F2" to go to BIOS settings
Find settings for Wifi+Bluetooth and set it to default.
Save settings and restart computer
You will be able to see your Bluetooth and Wifi.
Hope this works
