Bose Cinemate Digital Home Theater System Speaker Logo
A
Anonymous Posted on Jan 13, 2012
Device code for cisco RNG 150
I just got a Cisco cable box model RNG 150 and I want to program my Bose Universal Control that came with my Cinemate Home Theater System.
CEVICHE
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 17, 2014
CEVICHE
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
855
Points
Ok I know the post is kind of old, I mean the person asking about wanting to find the code for comcast Cisco RNG 150, all depends what Bose system do you have, the system I got is Cinemate GS series II that comes with an universal remote, and the codes for the Cisco brand cable box, it doesn't specify model code only Cisco cable box, anyways the codes are, 01877, 00877, 01982, now the last code worked for my universal control, don't know if it will work with other Bose controls, one thing I found out while browsing is that someone posted a cinemate manual with some codes but not for Cisco cable box they were for scientific Atlanta that are boxs comcast uses for the digital preferred system, the Cisco is use also for digital preferred but it has a different code, out of the three codes I posted earlier the first two were the same as the codes for the SA cable box, but the third one 01982 worked for mine. I hope this information will help someone. CEVICHE!!!!!
3 Related Answers
A
Anonymous
  • Posted on Feb 03, 2008
SOURCE: Bose Cinemate home theatre
I have a Scientific Atlanta Remote and I programmed the AUX to code 3033 and it worked. Also code 3034 is listed for Bose.
Good Luck
Anonymous
  • 217 Answers
  • Posted on Jun 03, 2010
SOURCE: code for uverse cisco box to bose cinemate series
hi i do have here a couple of codes for bose 4000, 2130, 2215, 2276, 6060,
5007
hope this helps! goodluck!
Anonymous
  • Posted on Mar 06, 2012
SOURCE: bose cinemate II control codes for cisco cable box
Try 01582
I have bose cinamate home system i need codes to programe it to my spectrum remote
To program your Bose CineMate home theater system with the Spectrum remote, you will need to use the appropriate remote control codes. These rules vary depending on the model of your Spectrum remote and the specific model of Bose CineMate you have. Follow these detailed steps to program your Spectrum remote to control your Bose CineMate: Find the remote control code: First, you need to find the remote control code for your Bose CineMate system. Spectrum provides a list of remote control codes for devices on their website or in the remote control user manual. You can also try looking up specific codes online using the model number of your Spectrum remote and Bose CineMate. Turn on Bose CineMate: Ensure that your Bose CineMate system is turned on and in the proper mode for operation (e.g., TV or AUX mode). Enter programming mode: Press and hold the "Setup" button on your Spectrum remote until the LED indicator on the top of the remote turns on. Enter Code: Use the number buttons on the remote to enter the four-digit remote control code of your Bose CineMate. The LED indicator blinks to confirm the entered code. Test control: After entering the code, point the Spectrum remote at the Bose CineMate system and press various buttons (e.g., volume up/down, power) to see if it controls your Bose system. If it works, the program succeeds. Save the code: When the remote control works with your Bose CineMate, press the "Setup" button again to exit the programming mode. Now that the code is saved, your Spectrum remote should be able to control your Bose CineMate. Please note that not all remote control codes may work with all models of the Bose CineMate. If you can't find a working code, you can try the code search feature in your Spec
Cisco rng 200 universal remote codes
0029,0022 are the codes to check. If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Problem with blu-link remote connecting with Cisco rng100 cable box
0029.0024,0029,0021. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts. Check this link too. http://electro-medical.blogspot.com/
2helpful
Looking the CISCO DTA50 code for GE Universal Remote Control
There is no setup codes for this device to any model GE remotes.
10helpful
Code for uverse cisco box to bose cinemate series
5007
Need Remote/Device Code for Comcast RNG 200 DVR
je recherche le code pour reprogramme d'une tv internet de model nritv2112 une tv bush
2answers
Device code for Samsung SMT-H3050 HD Cable Box
I use an old universal onkyo remote. 0035 Is a Panasonic code but worked the smt-h3050
Hope this helps
1helpful
3answers
The Bose codes for Comcast remotes for both the Cisco (labeled Xfinity) and Scientific Atlanta (labeled Comcast) DVR remotes are 31229 and 31933. 31933 worked with my Bose CineMate Series II
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
