The error code 545 or SC545 means that the fuser, also known as the fixer assembly has a thermistor problem (this part melts the toner onto the page). It could also mean that the fusing lamp is disconnected.
If a simple reset of the of the error code does not work ("Clear Mode"+107+"Clear/Stop" hold for 5s. Turn ON and OFF the Main Switch) you may need to have your machine serviced by a professional. It is your best bet to also have standard cleaning maintenance done by your on site technician after fixing the error.
SOURCE: functional problem within the copier. sc1-195
chek the scaner lamp and all other tins that is copieing in the macine
